Help to create Civ like icons
Hello, this is my first topic, and i'm from Brazil, so sorry from my bad english.
I Trying to make Civ V (A pc game) icons like this:
f24f660e8bc581515d32bcdeeb4085f3-d5m0wbg
I think that if i usede brushes and gradients i will make things like that, anyone have an idea?
Thanks
Welcome to the forum Gustavojose!
You can make the base button for the Prussia/Canada types with this plugin: Buttons
Then on a new layer, insert your artwork.  I used a symbol from the WingDings font - placed in the new layer with my WhichSymbol+ plugin (link in my signature).
Finally I added a light shadow with this plugin Drop Shadow.
For the type with the radial lightrays as a backdrop (Vandal Axeman) - try running this plugin on a new layer then cropping to the button edge LightRays.   To enhance this layer I blurred and reduced the opacity.
Assembling the icon:
The more complicated icons (of the people, for instance) are going to take a significant amount of illustration skill, though.
I don't have the skill to digitally illustrate those characters in those nice little logos though.
Perhaps it would help if you used an existing picture? And maybe there is a technique to make a real picture look like if it was digitally illustrated. Maybe a real PDN pro knows a way to make this happen.
Those logos make some nice profile pictures though.
