cindylee73 Posted February 14, 2013 Share Posted February 14, 2013 I have a color photo I want to change it to black and white (easy enough) Next I want to add some color into some flowers Example: Color Photo changed to Black and White My flowers from my wedding were all white...how do I add soft pink touches to the flowers? Thanks so much!!! Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted February 14, 2013 Share Posted February 14, 2013 Add a new layer and set the blend mode to multiply. Then, using the paintbrush tool, color the flowers. Stay inside the edges. It doesn't have to be perfect because... Use Gaussian blur to blend the color. Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 14, 2013 Share Posted February 14, 2013 Hello CindyLee73 - welcome!Have you seen this plugin? Extract Color? What it does is automate the Pleasantville effect(which is almost exactly the effect you're after). Read more here Pleasantville Effect. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
pdnnoob Posted February 15, 2013 Share Posted February 15, 2013 Hello CindyLee73 - welcome! Have you seen this plugin? Extract Color? What it does is automate the Pleasantville effect(which is almost exactly the effect you're after). Read more here Pleasantville Effect. The flowers had no color in the first place (white flowers), so those options won't really work here, though I highly recommend taking a look at the pleasantville effect tutorial (second link), as it uses a technique that may help you in your quest Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
cindylee73 Posted February 15, 2013 Author Share Posted February 15, 2013 Thank you for your quick responses! I used to work in Photoshop...about three years ago at a very beginner level. I did know to do layers but I was missing the blend mode part! You don't use it you lose it (: but thank goodness I am picking it up again with help of course! Quote Link to comment Share on other sites More sharing options...
