syllable Posted July 5, 2012 Share Posted July 5, 2012 I just put paint.net on vista now when I do a print it shows the Print Pictures software where you get choices of how many photos per page etc I don't recall that that happened with XP Is this normal for Paint.Net on vista? Quote Link to comment Share on other sites More sharing options...
kreemoweet Posted July 5, 2012 Share Posted July 5, 2012 Yes, it is. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 5, 2012 Share Posted July 5, 2012 Paint.NET just uses the built-in Windows Photo Printing Wizard. So whatever changes are made there will also be seen in Paint.NET's print command. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
syllable Posted July 5, 2012 Author Share Posted July 5, 2012 Thanks for that info. Seems strange to end up printing your work with a windows built-in app. At the moment I save my work as common formats like png etc and then open in another app (unmentionable) to print. Will Paint.Net gets control over the printing one day? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 5, 2012 Share Posted July 5, 2012 Try this: Printer+ Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
siowena Posted July 12, 2012 Share Posted July 12, 2012 I have an image 5cm x 11cm portrait. I cannot get the windows printing tool to show all the image - even when I change page orientation in the printer setting. It seems to truncate the top and bottom of the image. Any ideas on how to get the full image into the 'dumb' Windows print wizard. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 12, 2012 Share Posted July 12, 2012 From your post in the Printer+ thread I see you got this working Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
