Weazlebee Posted October 29, 2011 Share Posted October 29, 2011 (edited) X Edited September 4, 2021 by Weazlebee Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 29, 2011 Share Posted October 29, 2011 Teeth - go here: Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Weazlebee Posted October 29, 2011 Author Share Posted October 29, 2011 (edited) On 10/28/2011 at 11:19 PM, Ego Eram Reputo said: Teeth - go here: http://forums.g blockquote widgetblockquote widget Edited September 4, 2021 by Weazlebee Quote Link to comment Share on other sites More sharing options...
Weazlebee Posted November 1, 2011 Author Share Posted November 1, 2011 (edited) Edited September 4, 2021 by Weazlebee Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted November 2, 2011 Share Posted November 2, 2011 EER covered the teeth part already Skin: decrease the saturation Eyes: you can't edit the color of something black, but you can still add color to it. What I would do is similar to the colored eye tutorial: . It's a little more complicated than that since you need to increase the brightness of the eyes, though. Basically, you select her eyes, copy and paste them to a new layer, use the feather plugin to soften the edges, then increase the brightness. After that, you can change the color however you wish. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Weazlebee Posted November 3, 2011 Author Share Posted November 3, 2011 (edited) On 11/2/2011 at 2:32 PM, pdnnoob said: Skin: decrease the saturation Edited September 4, 2021 by Weazlebee Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted November 4, 2011 Share Posted November 4, 2011 which picture did you want her skin to look like? o.0 I'm confoozeled... Try messing with the brightness/contrast adjustment as well. It looks like you increased either the brightness or the contrast. Also, if you are trying to get the same skin tone as the second picture, you can add more blue to the image using curves or color balance. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Weazlebee Posted November 4, 2011 Author Share Posted November 4, 2011 (edited) X Edited September 4, 2021 by Weazlebee Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted November 4, 2011 Share Posted November 4, 2011 (edited) Skin: 1. Open hue/saturation and slide saturation down to 40 and hit ok. 2. Open the Brightness/contrast adjustment and set brightness to about 30 and contrast to about 25 and hit ok again. Lipstick: 3. Add a new layer and use the line tool to fill her lips with red. 4. Run Gaussian blur at about 3 5. Set layer blend mode to overlay and layer opacity to 80 Eyes: 6. Select her eyes (not the white though) with the ellipse select. You don't need to be too careful about getting more than you need since we will make further adjustments later. Just make sure you don't miss any pieces. 7. Copy and paste to a new layer 8. Run the feather plugin at around 5 9. Using the Brightness/contrast adjustment, set contrast to -20 10. Use the color balance adjustment to change the color. Use other adjustment tools like brightness/contrast to get the desired results. 11. Adjust blend mode as desired Flatten image and you're done! (if you already worked on her teeth that is... ) EDIT: I do realize the background is a bit brighter because of the brightness/contrast adjustment. If it bothers you a lot, just drop a not and I'll show you how to fix that too. Edited November 4, 2011 by pdnnoob Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
pdnnoob Posted November 4, 2011 Share Posted November 4, 2011 This tutorial might come in handy... Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
