Gaeriel Posted October 25, 2011 Share Posted October 25, 2011 (edited) This is a recreation of the "Manual Color Correction" tool in Paint Shop Pro. Basically it lets you change the colors by transforming one color into another. I mainly use it for skin color correction on portraits: select the original color of the skin in the picture as primary color, take something along the lines of RGB 200,180,160 as secondary color, and this tool, with default settings, should give you a nice warm skin color. There are a couple of settings: "Foreground To Background", checked on by default, takes your primary and secondary colors to work with. If you uncheck this, you can manually choose the two colors in "From" and "To". "Keep Hue","Keep Saturation" and "Keep Value" allow you to keep the original hue/saturation/value of the image. Essentially, if you put them all on 100, your image (almost) doesn't change. "Fix Value Discontinuity" and "Fix Saturation Discontinuity" could be useful when choosing colors in the extreme end of the value or saturation spectrum. It "shifts" both colors more towards the "middle" of the spectrum, giving smoother results (although changing these settings will prevent the "From" color to fully transform into the "To" color). Play with these settings if you get weird results This effect was made with CodeLab, and the source is included! (with Dutch comments.. sorry for that ) It's probably not nearly as efficient as it could be, so feedback is very appreciated! Hope you like it! As requested by BoltBait, here are some screenshots! First the "before" image, where people have purplish skin (it's a white balance thing, I never completely figured it out on my camera ) Here's the color correction tool with the used settings: And here's the result: ManualColorCorrection.zip Edited October 25, 2011 by Gaeriel 1 Quote Link to comment Share on other sites More sharing options...
BoltBait Posted October 25, 2011 Share Posted October 25, 2011 Welcome to the forum. You should add some screenshots to your first post so that people know what to expect when downloading your plugin. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
YARDofSTUF Posted October 25, 2011 Share Posted October 25, 2011 I love this! Quote Link to comment Share on other sites More sharing options...
namunger Posted January 18, 2013 Share Posted January 18, 2013 Does this effect install differently than others? I've got the .dll and .cs in the effects folder, but can't find it in the effects list. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 18, 2013 Share Posted January 18, 2013 The .cs file is not required, so you can delete it. The *.dll file goes in the /Effects/ folder. Restart Paint.NET and you'll find the effect in the Adjustments menu. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
whiteeagle1 Posted April 8, 2014 Share Posted April 8, 2014 Hi There:" I don't know why but my SuperAntiSpyware brought this .dll to my attention as a "critical threat." This is the first time I've seen this and I was running Paint. NET to do a quick project when the security was running a quick scan and came up with it. Any ideas? never had problems like this with anything from Paint.NET or any of you guys plug ins before...WOW! Thanks for any input. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 8, 2014 Share Posted April 8, 2014 The plugin was released 3+ years ago. If it was dangerous someone would have noticed by now. There have been 2208 downloads! I think you can assume that this is a false-positive by your spyware software. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
whiteeagle1 Posted April 8, 2014 Share Posted April 8, 2014 Hey Thanks very much, I guess I just needed some reassurance! Apologies. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 8, 2014 Share Posted April 8, 2014 No apology necessary You are right to be cautious. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
KellyJ13 Posted April 8, 2014 Share Posted April 8, 2014 Thank you I've been looking for something like this. Quote Link to comment Share on other sites More sharing options...
