shotgun2197 Posted December 8, 2010 Share Posted December 8, 2010 Whenever i try to intall Paint.NET again it doesnt work!i have made sure every last file has been removed also! This error pops up whenever i do try to install it System.TypeInitializationException: The type initializer for 'PaintDotNet.SystemLayer.FileSystem' threw an exception. ---> System.IO.IOException: The file or directory is corrupted and unreadable. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.Directory.InternalGetFileDirectoryNames(String path, String userPathOriginal, String searchPattern, Boolean includeFiles, Boolean includeDirs, SearchOption searchOption) at System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption) at System.IO.Directory.GetFiles(String path, String searchPattern) at PaintDotNet.SystemLayer.FileSystem..cctor() in D:\src\pdn\pdn_35x\src\SystemLayer\FileSystem.cs:line 506 --- End of inner exception stack trace --- at PaintDotNet.SystemLayer.FileSystem.TryDeleteFile(String filePath) at PaintDotNet.Setup.InstallingPage.<DoInstallation>d__21.MoveNext() in D:\src\pdn\pdn_35x\src\SetupFrontEnd\InstallingPage.cs:line 930 at PaintDotNet.Threading.IterativeTask.IterativeTaskAnon.<OnExecute>d__0.MoveNext() in D:\src\pdn\pdn_35x\src\Core\Threading\IterativeTask.cs:line 36 at PaintDotNet.Threading.IterativeTask`1.<>c__DisplayClass1.<StepTask>b__0() in D:\src\pdn\pdn_35x\src\Core\Threading\IterativeTask`1.cs:line 77 Any Help Or Ideas??!? please and thanks! Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 8, 2010 Share Posted December 8, 2010 System.TypeInitializationException: The type initializer for 'PaintDotNet.SystemLayer.FileSystem' threw an exception. ---> System.IO.IOException: The file or directory is corrupted and unreadable. ruh roh ... You need to run chkdsk. Search here on the forum and you'll find some instructions. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
shotgun2197 Posted February 27, 2011 Author Share Posted February 27, 2011 I have many things that i need to run Chkdsk on, but it doesnt let me run Chkdsk. Im sorry this is suck a late post, i kind of got side tracked... but my computer wont let me rin chkdsk Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 28, 2011 Share Posted February 28, 2011 ... my computer wont let me rin chkdsk It sounds like your hard drive is failing or corrupted. If you cannot run chkdsk then you require serious assistance. This forum is not a Windows technical support forum. You will need to seek advice from another source to solve this problem. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
