brwnbarbie Posted August 21, 2009 Share Posted August 21, 2009 I saved a banner image to my computer and the image has squares on it. I would like to import pictures into the squares. When I add a layer and import a picture, it takes over the entire screen and makes the original banner image much smaller. I'm not sure what I'm doing wrong. I have no idea how to do this and have read through pages of discussion topics and haven't found an answer yet. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 23, 2009 Share Posted August 23, 2009 You're importing images that are much larger than the banner. You need to resize the images down to the finished size they will be in the final banner. Then import them and move them into place. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Axle Posted August 25, 2009 Share Posted August 25, 2009 OMFG mega fail.....!.. if you hold ctrl it will stay the same ratio Quote My Deviant Art | My Gallery Link to comment Share on other sites More sharing options...
brwnbarbie Posted August 25, 2009 Author Share Posted August 25, 2009 Okay Ego, I will try that. Axle, I'm not sure what you mean. Quote Link to comment Share on other sites More sharing options...
Axle Posted August 25, 2009 Share Posted August 25, 2009 when resizing to stop a square image toring into a rectangle hold Ctrl button while dragging the corners while resizing and it remain a square. comprende'? Quote My Deviant Art | My Gallery Link to comment Share on other sites More sharing options...
Curmudgeon Posted August 26, 2009 Share Posted August 26, 2009 when resizing to stop a square image toring into a rectangle hold Ctrl button while dragging the corners while resizing and it remain a square. comprende'? actually, if you hold CTRL down it won't help at all...shift key on the other hand, will keep it a square shape... but, Ego Eram Reputo answered the question correctly as that was the problem she was having... Quote Link to comment Share on other sites More sharing options...
