HopefulAngel03 Posted August 2, 2006 Share Posted August 2, 2006 I was wondering if anyone knew how to make glitter graphics using PDN and Animation Shop? I can't figure it out to save my life and I'd be really thankful to anyone that can help me out. Link to comment Share on other sites More sharing options...
DigitalD Posted August 2, 2006 Share Posted August 2, 2006 do u think u could show an example. Thanks Edited by CMD: Maximum combined dimensions of all signature images must not exceed 500x150 You may remove this tag at your earliest convenience. Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 2, 2006 Share Posted August 2, 2006 Moved to General Discussion Note how the Tutorials section starts off with a post titled, "This section is reserved for tutorial publishing only ..." The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
HopefulAngel03 Posted August 2, 2006 Author Share Posted August 2, 2006 sorry, i didn't see where to request tutorials... but here's an example of a glitter graphic... Link to comment Share on other sites More sharing options...
DigitalD Posted August 2, 2006 Share Posted August 2, 2006 well ur probably want to make the hearts with PDN and the glittering with the Animation Shop thing...well you got to do it frame by frame. (i hope i am giving right advise ) Edited by CMD: Maximum combined dimensions of all signature images must not exceed 500x150 You may remove this tag at your earliest convenience. Link to comment Share on other sites More sharing options...
HopefulAngel03 Posted August 3, 2006 Author Share Posted August 3, 2006 idk, i know that you have to use layers to apply the glitter, and everything comes together in animation shop. Link to comment Share on other sites More sharing options...
AWF Posted August 3, 2006 Share Posted August 3, 2006 http://paintdotnet.12.forumer.com/viewtopic.php?t=1845 Thats a basic on glitter, not exactly what you where talking about, but you could abuse this to get the same effect, you would just need to lower the intensity very low and use the motion blur effect twice, in opposite directions on two different layers would get you somthing close, then a nice sharpen would probably do the trick. Link to comment Share on other sites More sharing options...
d1th3r_d3v1l Posted May 27, 2008 Share Posted May 27, 2008 They way I make glitter effects is copy the image 3-4 times then open paint.net, open the images 1 by one and add noise to them. Then save them and get an animation program to put them in gif format. Link to comment Share on other sites More sharing options...
LFC4EVER Posted May 27, 2008 Share Posted May 27, 2008 A link to a tut, it should help: viewtopic.php?f=15&t=3070&hilit=glitter ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::. Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 27, 2008 Share Posted May 27, 2008 Necroposting ...... The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
