Shadow and Water Reflection Test
Gameking53
I suggest using Displacement, instead of the water reflection plugin to create a more realistic reflection that suits the puddle. Use search to d/l the displacement plugin and take a look at the tut too, and you should sort of figure out how to work the plugin. :)
☆★☆★Merry Christmas★☆★☆
I like your 3rd pic, with the feathering. However, like LFC said, displacement ould probably work better because it would suit the puddle itself better (unless Luigi is causing the ripple, in which case you need to get rid of the shadow)
"pyrochild, you're my favorite person ever. We should go snowboarding some time."~ 007 Nab. Ish.
PDN Gallery | I Made a Deviant Art!
