corrigated cardboard - two versions - easy and medium dif
oma
two versions each teaches different method
When I first wrote this we were between version switches and the multi color gradiant was not avial (it was in process of revision). I did leave the old version further down just so you see there is always two or more ways to do things.
800 x 600
use multi color gradiant
color 0 BCAB85 color 1 A18F6A
check the alternating colors box and set the count as high as possible (20) angle is 90
on same layer now tile image set horizontal to 5 and vertical to 1 and make sure you check the box join edges.
time to make a duplicate layer.
and smooth just a bit the top layer using motion blur
uncheck the bottom layer (so you do not see it) and work on the top layer. see the top on is the blue highlighted one that way you know you are working on that one.
you will be using the selection lasso tool and taking out part of the side for the cut portion. so lasso your edge on top layer and hit the little sissor icon. you should see a checkered portion. This way you know you have transparency on that area of this the second layer.
at this point it is a good idea to feather the edge of that cut.
When you rip cardboard there is generally a bit of lighter portion this next gives those highlights. I'm sure you noticed that in the above picture the lighter edges in bit and places. here is what I did ..........
use the selection lasso and just catch in a few edges (we are still on the top layer)
I use under adjustments brightness and contrast.
we will give it a bit more depth now a bit of drop shadow (you should still be on the top layer !)
now is the time to just go in and check the bottom layer
flatten image
ta da easy version done.
THE OLD VERSION medium difficulty
This is not a difficult tut but you do have to pay close attention about when to duplicate a layer, when to merge layers and which layers you will be working on. I will type all caps where its important. Not shouting at you just want your full attention at that spot.
quick notes for beginners
this example was done on 800x600
colors primary BCAE88 secondary D3C39A
1)
effects>render>lattice
on this same layer
effects>blur>motion blur 2.05 centre checked 116 distance
"DUPLICATE THAT LAYER "
"ON THE BOTTOM LAYER"
effects>stylize>emboss at 90 degrees
"ON THE TOP LAYER"
set blend mode to reflect at opacity 141
"MERGE THOSE TWO LAYERS TOGETHER"
"NOW DUPLICATE THE LAYER"
so you have two layers again
use height to field plug in. viewtopic.php?t=2973
this you will see changes the color to blue don't worry. next step will fix that.
you are still working on the bottom layer the height to field layer
effects>color>colortint at default ""BOTTOM LAYER"
"ON THE TOP LAYER"
set your blend modes to darken and opacity to 156
"MERGE THE TWO LAYERS"
tricky bit for beginners
change the window size to 33% use the move pixels tool and clik anywhere within the paper
pull the nubs out to the edge of your screen. NOTE: the paper doesn't move to the edges just the nubs beleive me the pattern its stretched out .
after you have stretched the paper
effects>blur>motion blur o angle 90 distance
"ON THE TOP LAYER"
we are now making the smooth outer portion
effects>blur>gausian blur 11
still on the TOP LAYER
use the lasso tool and do your selection for cutting away either sissors or delet button will get rid of that portion.
As suggested by LFC4EVER below
at this point after cutting, you can use feather or aa on this layer if you want a smoother edge. This is totally up to you. I didn't as I liked the ragged edge, but if you feel you want smoother now is the time to do so.
highlights still on TOP LAYER
Note: I unclik the bottom layer at this point so I can see the torn edge better.
use lasso tool again and just catch portions of the to cut/torn edge. Try to leave some areas not in the lasso portion.
Use adjustments>brightness and contrast
anywhere between 7 and about 30
still on TOP LAYER
drop shadow
go back and re check that bottom box so you see both layers again
""""MERGE LAYERS TOGETHER """"
you should now have shallow thin cardboard
this ends the basic tut.
ADDITIONAL OPTIONS
at this stage to get thicker darker cardboard
duplicate your finished cardboard and set top layer to multiply play with the opacity adjustment down wards until you get the color you want.
some of you may wish to add frosted glass along the torn edge prior to doing the brightness/contrast edges step.
play with it
Good job Oma! You finally posted it, theres just one mistake where you say Duplicate the blur layer, but the arrow points to the Add a new layer icon. :D
:) Visit-> My Website <-Visit :)
Please Call Me Elite Override
The trick to flying is throwing yourself at the floor and missing.
thanks took me awhile to scoot down the number of steps to begginers level. I'd personally add quite a bit more on this but wanted to do simple, and easy to follow this time round. I'm more than pleased with how it turned out. It was more to answer those pesky questions about how to merge layers, duplicate layers, and set blend modes.
Thanks Oma, great work! It was well explained and this is my attempt (I know the tag needs to be feathered more and - lol - that's my poor attempt at putting a ribbon inside the hole, as for knotting a tie on it I wish I had the power to do it :lol: )
  • 4 weeks later...
