Ace Falcon Posted July 16 Share Posted July 16 I need to find a way to have my font bent like this, Can anyone help me? Quote Link to comment Share on other sites More sharing options...
frio Posted July 16 Share Posted July 16 (edited) First run a Tube Oblique to turn it cylindrically bent along X direction: Then use the built in rotate/zoom command (Layers->Rotate/Zoom, control-shift-Z) to give it perspective. Recommended to work in higher resolution than you need and then scale down to correct size afterwards, so any pixelation or blur from doing 2 distortions will be minimized. Edited July 16 by frio 1 Quote Link to comment Share on other sites More sharing options...
Ace Falcon Posted July 16 Author Share Posted July 16 Is that a plug-in or already a feature in the app? Quote Link to comment Share on other sites More sharing options...
null54 Posted July 16 Share Posted July 16 19 minutes ago, Ace Falcon said: Is that a plug-in or already a feature in the app? Tube Oblque is a plugin, Layers->Rotate/Zoom is built-in. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
