Simon Brown Posted February 15, 2010 Author Share Posted February 15, 2010 Make sure you double-click the file that says "open this." Quote Link to comment Share on other sites More sharing options...
phamduongthai Posted August 17, 2010 Share Posted August 17, 2010 i pressed ctrl like lixv91 said when i clicked the link. it works for me ^^ Thanks! Quote Link to comment Share on other sites More sharing options...
blackswan Posted September 8, 2010 Share Posted September 8, 2010 Hi, I've downloaded the app & tried to watch the tutorial clip but the link doesn't work for me either. Read all the suggestions in this section, tried Google Chrome & IE8, using Control Enter etc but got msg: Page not found. The link has moved?? Pls advise! Thks so much Quote Link to comment Share on other sites More sharing options...
DNorris Posted October 12, 2010 Share Posted October 12, 2010 works great for me, thank you Simon, im new at this, and that was very simply laid out and walked thru. Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted January 3, 2011 Author Share Posted January 3, 2011 I've just published a new version, hopefully this one will work better. Quote Link to comment Share on other sites More sharing options...
schonemonalisa Posted October 3, 2011 Share Posted October 3, 2011 Yep, it works. Thanks for uploading. Quote Link to comment Share on other sites More sharing options...
dabean Posted September 6, 2013 Share Posted September 6, 2013 Hi Great tutorial. How do I open the layers editing box that shows in the right hand of the tut ? Quote Link to comment Share on other sites More sharing options...
ajaxfc Posted September 9, 2013 Share Posted September 9, 2013 Is there any way to get tutorials in text as opposed to a video? Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted September 9, 2013 Share Posted September 9, 2013 The old version was a video. The new one is more like a slideshow you can click through. I would like to point out that the tutorial isn't designed to get a specific result, but rather to introduce you to the tools you have available to you. Not all of the steps are necessary, and the order in which you do them is for the most part arbitrary. Technicalities aside, here's the text from each step (with a little paraphrasing by yours truly): 1. Open your image 2. Select all (Edit>Select All or ctrl+A) 3. Use the "move selected pixels" tool (it's the black pointer in the tool window) to resize and/or move the image as needed. 4. Go to the Layer menu and click "Import from file." Select your second image and click open. 5. Again, move and resize the image as needed. 6. Double click on the layer in the layer window to change the layer properties if so desired. You can also access the layer properties by pressing F4 on your keyboard. 7. Deselect (Edit>Deselect or ctrl+D or esc) 8. Use Rotate/Zoom (Layer>Rotate/Zoom or ctrl+shift+z) to rotate, pan, zoom, tilt, etc. as desired. Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
SwankyDoodleSandy Posted July 4, 2018 Share Posted July 4, 2018 On 10/20/2008 at 1:48 PM, asian_skillz said: Ummm, your link is broken. I couldn't get to it... Is it just me? I can't either. Sigh. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted July 4, 2018 Share Posted July 4, 2018 @SwankyDoodleSandy, the link to the tutorial seems to working fine for me. What exactly is the issue? What do you see? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
SwankyDoodleSandy Posted July 4, 2018 Share Posted July 4, 2018 (edited) I refreshed and was able to get through. Thanks. I'm new to this site and wandering around feeling not too smart. I appreciate your help. Edited July 4, 2018 by SwankyDoodleSandy Quote Link to comment Share on other sites More sharing options...
