Daniel67400 Posted November 26, 2017 Share Posted November 26, 2017 Bonjour, Ma question: dans paint.net, quand on clique sur l'outil "déplacer les pixels sélectionnés", on peut pencher le texte. Mais une fois le texte changé d'angle, je ne peux plus le modifier(rajouter ou supprimer un caractère). Y-a-t-il une solution? thank you , merci. dmau@free.fr Quote Link to comment Share on other sites More sharing options...
Pixey Posted November 26, 2017 Share Posted November 26, 2017 Hi @Daniel67400 & Welcome to the forum . I'm sorry, but we must use English on this forum. I have translated your question: "My question: in paint.net, when we click on the "move selected pixels" tool, we can lean the text. But once the text changed angle, I can not modify it (add or delete a character). Is there a solution? thank you, thank you. " Answer: Please make sure to un-select the Tool to delete. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Daniel67400 Posted November 26, 2017 Author Share Posted November 26, 2017 8 minutes ago, Pixey said: Hi @Daniel67400 & Welcome to the forum . I'm sorry, but we must use English on this forum. I have translated your question: "My question: in paint.net, when we click on the "move selected pixels" tool, we can lean the text. But once the text changed angle, I can not modify it (add or delete a character). Is there a solution? thank you, thank you. " Answer: Please make sure to un-select the Tool to delete. hi Pixey, where is the tool to delete? Quote Link to comment Share on other sites More sharing options...
Pixey Posted November 26, 2017 Share Posted November 26, 2017 (edited) Hi - Just hit delete on your computer. Also - see this diagram to move selected text. Also: Edited November 26, 2017 by Pixey Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Daniel67400 Posted November 26, 2017 Author Share Posted November 26, 2017 my concern is that if I write a word (photo 1) and I click on move the selected pixels (photo 2), if my word is wrong, I can not rectify it after Quote Link to comment Share on other sites More sharing options...
Eli Posted November 26, 2017 Share Posted November 26, 2017 (edited) Paint.net is an image editor not a text editor. If you want to modify text you must delete and retype. Sorry, It is a feature not supported by Paint.net. Edited November 26, 2017 by Eli Quote Link to comment Share on other sites More sharing options...
Pixey Posted November 26, 2017 Share Posted November 26, 2017 Also - you should have your text on a new transparent layer. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Daniel67400 Posted November 26, 2017 Author Share Posted November 26, 2017 ok. I asked the question with paint.net because you can do it with libreoffice.here is what I do: I put street names on a map.Thank you for your answers. Quote Link to comment Share on other sites More sharing options...
Daniel67400 Posted November 26, 2017 Author Share Posted November 26, 2017 8 minutes ago, Pixey said: Also - you should have your text on a new transparent layer. yes, I add a new transparent layer to add the names. bye Quote Link to comment Share on other sites More sharing options...
Eli Posted November 26, 2017 Share Posted November 26, 2017 It is not possible with Paint.net. If you really need that feature then just do it with Libreoffice. Quote Link to comment Share on other sites More sharing options...
MadJik Posted November 26, 2017 Share Posted November 26, 2017 Hi @Daniel67400 As you use LibreOffice, I suggest you type in all your text in a document to refere to it later if necessary. If you create a table you could also have some more columns for the location x,y on the map, the font size, the full text if you use short terms, etc... Quote My DeviantArt | My Pictorium | My Plugins | Donate via Paypal Link to comment Share on other sites More sharing options...
