missm3 Posted November 27, 2016 Share Posted November 27, 2016 Hi, please Is it possible to stretch corner of my picture (not enlarge the picture) I want to cover the pillow corner, with the corner of picture, but I need to keep all image on the pillow...see picture I put arrow to show ... Thank you for your help Quote Link to comment Share on other sites More sharing options...
Eli Posted November 27, 2016 Share Posted November 27, 2016 Try Grid Warp... Quote Link to comment Share on other sites More sharing options...
missm3 Posted November 27, 2016 Author Share Posted November 27, 2016 Can you explain a little bit please, I'm french person, I try to find grid warp, but I don't know what you mean. Thank you Quote Link to comment Share on other sites More sharing options...
Eli Posted November 27, 2016 Share Posted November 27, 2016 Look under Effect>Tools>Grid Warp. This tool will allow you to stretch the corners of the pillow all the way to the canvas corners. Or you could just select the entire image and stretch it until you are satisfied. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted November 27, 2016 Share Posted November 27, 2016 Eli, you should explain that Grid Warp won't show up until it is installed. missm3, you can download Grid Warp here: Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Eli Posted November 27, 2016 Share Posted November 27, 2016 Thanks BoltBait. I have so many effects that many times I forget which ones are part of Paint.Net and which ones have to be installed. Quote Link to comment Share on other sites More sharing options...
dipstick Posted November 27, 2016 Share Posted November 27, 2016 GridWarp distotion example on your image: Quote Link to comment Share on other sites More sharing options...
Pixey Posted November 27, 2016 Share Posted November 27, 2016 Hi @missm3 and Welcome to the forum . You could also use the Smudge Tool to get rid of the extended edges. How to install Plugins: https://boltbait.com/pdn/InstallingEffects.php Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
missm3 Posted November 27, 2016 Author Share Posted November 27, 2016 Thank for your help, I will test all your suggestion Thank you very much! Quote Link to comment Share on other sites More sharing options...
