Posts
5,020 -
Joined
Last visited
Days Won
155
Posts posted by toe_head2001
Please post a screenshot of the error message.
Sounds like you might have a naughty shell extension installed.
Please post the diagnostic information found within paint.net.
Settings -> Diagnostics -> Copy to clipboard.
I did some bisecting this afternoon. It's been broken for approximately 1 year.
Working: 22.4.1 (April 5, 2022)
Broken: 22.5.2 (May 23, 2022)
(there a few minor releases between these two versions that can be bisected further, but I just used what was already in my Downloads folder)
I also submitted a bug report to AMD.
- 1
5 minutes ago, Alfy said:
Would it be possible to incorporate this feature of ignoring corrupt chunks in some sort of update
The updated
/ignoreCorruptPDNChunks
parameter was included in v5.0.4.https://forums.getpaint.net/topic/122540-paintnet-504-is-now-available/
- 1
I just tried this with my RX 6600. Can confirm the issue.
Definitely a driver bug when the image resolution is high enough.
I'm not sure if this a new bug with the latest Radeon driver, as I never tried using such a large image before.
I will do some version bisecting over the weekend... to satisfy my curiosity.
- 1
Settings -> Diagnostics -> Open crash log folder
I don't understand your question, since "thread" and "topic" are synonyms in this context.
- 1
On 4/29/2023 at 9:19 AM, Cferra1227 said:
Pentium G2020
Also make sure the graphics driver for your G2020 chip is up-to-date.
Paint.NET is crashing without a crashlog? Okay, let's try this:
Right after the paint.net crashes, please open the Windows Event Viewer and look in the Application log. (Event Viewer -> Windows Logs -> Application)
The items should be sorted by datetime, so the most recent item should be at the top of the list.
Let us know what you find.
The domain is already registered by a large paint company. They are unwilling to sell the registration for a reasonable price.
4 minutes ago, Cferra1227 said:
Here's the crash log.
You posted the diagnostic info. We need to see an actual crash log.
13 minutes ago, AMD_Ryzen said:
Is there any way to automatically expand canvas when pasting an image that is larger than canvas? I would really really like to skip that prompt
Edit -> Paste into New Image (Ctrl + Alt + V)
There's no other way.
13 minutes ago, AMD_Ryzen said:OR launch Paint.NET with 3840x1080 resolution with one mouseclick.
Create a template file with your preferred resolution, and start paint.net by opening that file.
- 1
I found the cause the crash. It is indeed caused by bad values being passed to DrawArc.
The pen is too wide for the bounding rectangle!
I am able reproduce this in LINQPad.
(I'm using values I pulled out of the VS debugger at the time of the exception.)
Changing the pen width from 2 to 1, and the tiny arc is drawn successfully:
I'll post a bugfix release sometime within the next week or so.
- 1
- 1
Hi @Lisa
You can try the Frames plugin.
https://forums.getpaint.net/topic/6210-frames/
If you actually provide a link to the video, we could more easily identify the specific plugin.
Hi @CircleBox
Despite the exception message, this is not a VRAM issue (or even a system RAM issue).
Most likely, a bad value was simply passed to the DrawArc function.
If you have the steps to recreate the crash, it can potentially be fixed.
Alternately, you can try BoltBait's Hue / Saturation+ plugin.
Make sure you're installed the plugin correctly.
You should have 4 files within a subfolder.
Within Paint.NET, you will find it in the menus: Effects -> Tools -> Dynamic Draw
- 1
Please read our community rules:
https://forums.getpaint.net/topic/2932-read-first-the-rules/
Do you use the "Controlled folder access" option in Windows Defender?
Or use another overly aggressive security software?
- 1
32 minutes ago, Ellie Amore said:
But I'm going to keep it in dark mode. I like it!
We also have a dark theme here on the forum.
- 1
12 minutes ago, Shijindrake said:
I have Paint.NET version 5.0.3.
Did you obtain Paint.NET through the Microsoft Store?
I've fixed the image in Manc's post so it displays properly.
- 2
52 minutes ago, ppdemo said:
the question is that it doesn't work the same way for me
I'm not sure I understand your issue.
Is there an actual deficiency with BoltBait's plugin? or are you just unwilling to adjust to a different plugin?
3 minutes ago, Meow. said:
the 2 errors point to temperature dll and webp file type dll. any hints thx
You simply delete those two DLL files.
- 1
- 1
You can't set a default size for new images.
You're seeing 2,000 x 1,500 because there's an image on your clipboard with that size.
Need a download link :)
Posted
You can try downloading from GitHub.
https://github.com/paintdotnet/release/releases/latest
