Posts
5,029 -
Joined
Last visited
Days Won
155
Posts posted by toe_head2001
First of all, you using the wrong app. What you want is Visio. (That is, if you want to use another MS app.)
I would use the Pencil Sketch effect on the photo, and then layer that on top of the Etch-a-Sketch.
https://www.getpaint.net/doc/latest/EffectsArtisticMenu.html#8
I would just use the gradient tool for a border like the one in that pic.
A quick add of text to this [very low quality] pencil.
You can use PNGout or this online tool if you aren't the command line type. PNGout is great, but I have not used the other one
where am i supposed to download it? there was no link
End result will look more or less like this (without the paper of course).
See more variations of the tape at the end of this post.- Start with a transparent canvas
- Set your Primary Color to D8D8D8
Use the Shape ( ) tool to draw a solid ( ) rectangle with the height of 25px and a width of what ever you like. (I used 100px)
Use the eraser ( ) tool with Antialiasing disabled ( ) at a Brush width of 1px, to cut out triangles on both ends. Like so...
Zoomed in to show detail: - Set your Primary Color to C0C0C0
Use the 'Outline Object' plugin to make a border around the tape. Radius of 1 and Strength of 10
Use the 'Feather Object' plugin, with a Feather Radius of 1
- Rotate the tape to 45 degrees using Zoom / Rotate ( ). You may have to expand your canvas first
Set the layer Opacity to about 175 ( )
There's your Scotch Tape: - Now just put your paper or photo into a new layer under this one.
And if you want a more transparent tape or finer torn edges, see below for some variations:
Thanks for fixing up the red X close button! Now how about the drop down list button ()as well.......por favor
A few mock ups I've made in the past:
You mean we just need to make mock ups, and not an actual finished product.
Before the forum design contest, we need to wait for phpBB v3 to come out. The last thing you want is to make a new theme, then have it get broken a week later by the new version.
I have seen it. I tried do download it, but my CPU won't let be because of the dll extension.
Your CPU won't let you....
This plugin is, by far, the best one ever.
Just need to add values to make it more 3d
I not even going to comment on this, the pic says it all!
Thanks. This is a very Useful tutorial.
Oh...I spelled Reel wrong
It needs to make a come back!
Blue Mock Up:
Blue Modified Mock Up:
If anyone ever does a view of the back of a box, I think it would be cool to use the Barcode Plugin, to make a real barcode. (even though no one would know the difference, it would be cool!)
Barcode Plugin
That isn't three bad actually, but personally I don't mind as long as its functional and does what it says on the side of the tin.
I feel stupid. It took me way too long to get that!
I feel even more stupid, because I have no idea what he's talking about. Is it just a typo, bad grammar, someone explain please!
My Mock Up:
Current:
You could also use the jpeg2000 format, which supports transparency. You'll need the plugin:
Viewing PDN files online?
Posted
PDN files are raw data. (As far as I know)
PDN is to image as an un-rendered animation is to video.
