Posts
5,020 -
Joined
Last visited
Days Won
155
Posts posted by toe_head2001
According to Microsoft's documentation, a value of 0 is acceptable for an uncompressed RGB bitmap.
https://learn.microsoft.com/en-us/windows/win32/api/wingdi/ns-wingdi-bitmapinfoheader
Your friend should submit a bug report for whatever software he is using.
As a workaround, he can also re-encode the bitmap using a tool like Imagemagick, which is included by default with many GNU/Linux distros.
- 1
- 1
13 minutes ago, ppdemo said:
what is the alternative to this plugin?
You can use BoltBait's Apply Alpha Mask plugin.
The TIFF format doesn't support animated images.
Why would you want to use the TIFF format anyway? It is considered to be a legacy/obsolete format.
8 minutes ago, Discographer said:
I get to a point, where there is a flaw and I can't go on.
Can we get some details about this? Like, do you see an error message?
Please post the diagnostic information found within paint.net.
Settings -> Diagnostics -> Copy to clipboard.
Let's make sure you understand what you're asking for...
With 3 character HEX codes, each R, G, or B range is limited to 1 of 16 possible values. So only a total of 4,096 colors can be represented.
16^3 = 4,096 possible colors
With the standard 6 character HEX, it's 1 of 256 possible values for each of the 3 (R, G, and B).
256^3 = 16,777,216 possible colors
You can use the Signature Stamp for watermarking.
https://forums.getpaint.net/topic/112441-signature-stamp/
If you want to watermark a whole batch of images, you should IrfanView instead.
- 1
There is no 'Save All As' feature.
Sounds like you're just trying to do a batch conversion.
IrfanView can batch convert .pdn files to .png files. You should use that.
That would indicate all open files have already been saved.
ie. No unsaved changes.
Right after the paint.net crashes, please open the Windows Event Viewer and look in the Application log. (Event Viewer -> Windows Logs -> Application)
The items should be sorted by datetime, so the most recent item should be at the top of the list.
Let us know what you find.
I've changed the download links to use HTTPS.
- 1
- 1
Some browsers block HTTP downloads. I'll change the links to HTTPS.
- 1
- 1
A 'Recently used fonts' feature has been suggested in the past. More details here:
https://forums.getpaint.net/topic/116709-feature-request-recently-used-fonts/
Sounds like you have an existing paint.net installation that has become broken. Please use this utility to remove the broken installation:
Afterwards, you should be able to install paint.net anew.
As I said, the work-around is to change the scaling in Windows to 100%.
Your screenshot are way too tiny to see what's going on.
It's probably just a HiDPI scaling issue though. Try changing to 100%.
Yes, take a look the Dynamic Draw plugin.
The setting you want to set within the plugin is called "Symmetry: At Points"
- 1
- 1
28 minutes ago, Shambles_SM said:
pixel-perfect in case of drawing a straight line with an even number of pixels? Right now, a 2px line (with Shift) looks like this
If you want to disable the anti-aliasing, there a button for that in the toolbar.
2 minutes ago, TheDuckDealer said:
The new one isn't really doing what I want.
Perhaps you simply haven't mastered the new version yet. What are you trying to achieve?
I think you'd better read the instructions again. It sounds like you're trying to create the folders in the wrong location.
- 2
3 hours ago, Timo Kinnunen said:
I get a 100% reproducible crash of paint.net when typing the indicated dot '.' in the following code snippet in CodeLab 6.8:
This has been fixed for the next release of CodeLab.
- 1
- 1
Hi @todor-dk,
Although PerMonitorV2 can be enabled in WinForms, it's not actually well supported. Many controls will recalculate their sizes incorrectly, and the the UI becomes unusable.
Fixing the PerMonitorV2 bugs remains a priority for WinForms team/contributors, so hopefully it will be in a good state when dotnet 8 is released in November.
https://github.com/dotnet/winforms/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc+PerMonitorV2
Barcode v1.5.1 (Nov 23, 2018)
in Plugins - Publishing ONLY!
Posted
It's possible, but adding new functionality to this plugin is not high on my list of priorities.
This plugin needs a complete rewrite too.
Sepcot originally created it 16 years ago, and so it uses some outdated coding conventions. Then I retrofitted UPC functionality into it... in a very hacky way.
