Tillerman Posted March 31, 2008 Share Posted March 31, 2008 I have tried everything in my power to make the text of this image appear. But have been largely unseccesful. Can someone please help me? It is important. Quote My Internet Explorer 8 Concept.... My Deviant Art My Forum Link to comment Share on other sites More sharing options...
Simon Brown Posted March 31, 2008 Share Posted March 31, 2008 Maybe type it again and use Ctrl-Shift-Z to change the angle? Quote Link to comment Share on other sites More sharing options...
Tillerman Posted March 31, 2008 Author Share Posted March 31, 2008 Maybe type it again and use Ctrl-Shift-Z to change the angle? They aske for a Photo. If I did that, it would not look convincing. Quote My Internet Explorer 8 Concept.... My Deviant Art My Forum Link to comment Share on other sites More sharing options...
Simon Brown Posted March 31, 2008 Share Posted March 31, 2008 Produce the text in exactly the same way in a new image and take an image from above. Then combine them and do the angle thing. Quote Link to comment Share on other sites More sharing options...
pyrochild Posted March 31, 2008 Share Posted March 31, 2008 That's really blurry. There's only so much you can do to de-blur an image. Try first using Brightness/Contrast to make the letters contrast more with the background, then use Sharpen+ to enhance the clarity of them. Don't overdo the sharpening, or you'll actually just make it worse. Next, zoom out. When smaller, blurry letters are actually easier to read. Sometimes. Finally, squint. Squinting also helps with blurriness. If you have access to the object in the photo, just retake the photo. You might need to adjust the angle you take it from, the distance you take it from, the zoom level, the focus (if the camera lets you adjust that), lighting, etc. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
BoltBait Posted March 31, 2008 Share Posted March 31, 2008 Put your camera in Macro mode and retake the picture. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
