MJW, please don't distribute a modified CodeLab.
I love what you've done and I'll include it in the next release of CodeLab.
But, in the future, just PM me something like that and I'll look at it. I usually accept code contributions.
I've got some other small changes already done, so I'll look at your code this weekend and incorporate it. Then I'll make an official build.
Click to play:
Thank you very much, BoltBait, but I'm not sure such a minor contribution warrants inclusion in the About menu, and for some reason I'm reluctant to have my actual identity revealed (I use my MJW handle on many sites besides Paint.NET forums). So for right now, I'll just remain the anonymous MJW.
CodeLab 2.5 Released
This is only for Paint.NET 4.0!
Changes:
▪ Two buttons added to the "View Source" screen.
▪ You can no longer build untitled files to dll. (Requested by skyoxZ)
▪ Added UI Elements Renumber command. (Requested by MJW)
Grab the CodeLab DLL here:
How to Renumber UI Elements
The easiest way to work with CodeLab is to design your UI first, then write the code to your effect. I usually do this using the UI Designer located in the File > User Interface Designer menu. For example, let's say you want to design an effect with a foreground and background color selection. After using the User Interface Designer your code may look like this:
#region UICode
ColorBgra Amount1 = ColorBgra.FromBgr(0,0,0); // Foreground
ColorBgra Amount2 = ColorBgra.FromBgr(0,0,0); // Background
#endregion
Now, let's assume you've written your effect and everything's working fine. Then, later you decide to add an Alpha control for each of the color wheels. Here's the best way to do it:
Use the UI Designer to add 2 new Alpha Controls to the bottom of the list. After doing that, your code will look like this:
#region UICode
int Amount3 = 255; // [0,255] Foreground Alpha
int Amount4 = 255; // [0,255] Background Alpha
#endregion
At this point, you can write the code that makes the new controls work... or you can wait until you've reordered the controls.
You'll probably want the alpha controls under the corresponding color wheel controls. In order to do that, carefully reorder the lines of the UICode block, like so:
#region UICode
#endregion
DO NOT change the variable names... let's let CodeLab do that for you!
Notice in our code above, we've moved the Alpha slider Amount3 to just below Color wheel Amount1.
At this point you're ready to renumber the controls. Use the menu option File > Renumber UI Variables. After, your code looks like this:
#region UICode
int Amount2 = 255; // [0,255] Foreground Alpha
ColorBgra Amount3 = ColorBgra.FromBgr(0,0,0); // Background
#endregion
...and all of the rest of your code has been updated as well.
I also modified the User Interface Designer so that if you open it when the UI controls need to be renumbered, it will do that for you before the UI Designer opens.
NOTE: Although it is possible to reorder controls in the UI Designer, you will need to update your code manually to handle your changes done this way.
Click to play:
  • 2 months later...
I have a few related suggestions:
When CodeLab generates a new file, it should include the following type of header, with the entries left blank:
// Author:
// Name:
// Title:
// Submenu:
// Desc:
// Keywords:
(When building the DLL, blank fields should be ignored.)
The header should have fields for everything on the Build DLL menu except the icon. I don't believe there's currently any way to specify the version (and subversion) or that the plugin is an Adjustment.
When building the DLL, if the DLL builder can't find the icon .png file in the "source" directory, it should look in a "source\icons" subdirectory. That would make it easier to organize the icons.
I realize I can always copy the header from another file, and there isn't that much that needs to be entered in the DLL build menu, but my suggestions would make it easier (and prevent me from forgetting to enter the version number when building -- which I always seem to do.)
Edited by MJW
// Author:
// Name:
// Title:
// Submenu:
// Desc:
// Keywords:
That's a darn good idea. I'll make that change for the next release.
Meh. I don't know about this one. Maybe. I'll think about it.
...and prevent me from forgetting to enter the version number when building -- which I always seem to do.)
I should make a comment for the version number too.
Click to play:
Thank you, BoltBait. Having the DLL Build entries automatically filled in from the comments has certainly saved me a lot of annoyance. It was only recently I discovered that if the icon file is in the Source directory, I wouldn't have to enter it myself.
Hi! So, I've been a happy user of CodeLab in the past (I created the Grim Color Reaper effect). However, updating Paint.net to 4.0.5 and CodeLab to 2.5, there are some puzzling issues:
1. Undo (Ctrl+Z) doesn't seem to work, it just moves the cursor back to the place of the last edit. This makes any editing final and is quite frustrating.
2. Code completion / Intellisense was announced but I can't seem to trigger it in any way (tried: hover text, select text, right click, tab, Ctrl+Enter).
3. If your filename is "Untitled.cs", CodeLab says you must save your file before compiling to dll (minor issue but can be quite confusing if you're firing up CodeLab for the first time and doing a quick test, giving the impression that it doesn't work).
Jotaf
1. Yeah, Ctrl-Z doesn't work because now that I'm using a custom editor control (for syntax highlighting, etc.) I'd have to write my own Ctrl-Z undo handler. I'm just too lazy to do it. It is a pain, seriously. I actually spent half a day trying to implement this and I couldn't get anything to work acceptably. So, I gave up.
2. Code completion works when you press the "." key. For example, inside of your render loop, type:
Color.
After pressing the "." you should see a list of options. Arrow down and press "enter key" or "tab key" to select one.
3. CodeLab works just fine for tinkering. You don't need to name your effect if you don't plan on saving as a dll file. If you do plan on saving as a dll file, you must save your script first so that CodeLab will know what to name the dll file. This name is also used for the namespace. By specifying a unique filename/namespace, you prevent plugins walking all over each other.
Click to play:
CodeLab 2.6 Released
Changes:
▪ Added empty script comments to the default script for build screen default values. (Requested by MJW)
▪ Fixed processing of script comments for when comments are empty.
▪ Added 4 forms of help capability to built effects. (Tutorial 6) (Requested my MJW)
▪ Added help content editor to Save as DLL screen.
▪ Added // Help: comment for help content.
▪ Added "custom help" to File New templates.
▪ Cleaned up "using" statements for compiled scripts.
▪ Cleaned up some of the File New template code generation.
▪ Added access to current and default palettes in File New templates. (Requested by MJW)
  • Upvote 5
Click to play:
Lovely! Thanks for all your hard work BoltBait :star:
When I try to build CodeLab26, I get the following error:
The designer cannot process the code at line 716:
this.largeFontToolStripMenuItem.CheckState = (EditorInLargeFontMode) ? CheckState.Checked : CheckState.Unchecked;
The code within the method 'InitializeComponent' is generated by the designer and should not be manually modified.
Please remove any changes and try opening the designer again.
I know I've had the same problem building previous versions, but I can't for the life of me remember what I did about it. I can tell VS to ignore the error and continue, but I'm a little nervous about doing so, because it gives me one of those, "Are you absolutely certain you want to do this? Continuing may end civilization as we know it!" warnings.
I'm not sure what you mean. I only opened the file in the sense that I loaded the solution into Visual Studio (by clicking CodeLab.sln) to build the project. I didn't modify or specifically open any of the files before clicking Build Solution.
Edited by MJW
I have a suggestion. I think the double-vector position control should be changed to three decimal places instead of the current two. As it is, there are only 200 or so possible values, which means for most reasonable window sizes, the position cannot be placed within a pixel. Even with three decimal places, positioning for large windows wouldn't be within a  single pixel, but at least it would usually be fine enough to be useful. I didn't use the position control in my Texture Shader plugin for that very reason.
Edited by MJW
I have no control over the precision of the double-vector control. That would be something for Rick to implement.
If you need more precision than the double-vector control can offer, try using one of the individual slider types (int or float).
Click to play:
That's too bad. I assumed (without looking) that it was one of those values that could be set in all that IndirectUI initialization code.
I do use the sliders instead, but for positioning within the window, they seem inelegant compared to the position control.
You can change the Double Vector UpDownIncrement in VS if that helps. Won't show another digit but means you can fine adjust with the up/down slider end arrows.
Try my 'Gears' plugin for an example.
Three decimal places as default would be better though IMO!
I may eventually change the Texture Shader to a VS project. The only reason I don't usually make VS plugins is that I prefer to make the code easily available, and if other people are like me (which they may not be), I'm more likely to experiment with plugins I can build in CodeLab the ones that I've got to make a VS project for.
I think having the control change the position without showing any change in the control values might be somewhat confusing. Maybe Rick will consider adding some precision control to the double vector control, or just make it three places, which I think is more useful than two.
