CodeLab v6.0 (for advanced users) Released June 25, 2020
Also, some fun with networking! A polar distortion based off of an image taken from nik.bot.nu (advice: slightly maybe NSFW).
Supposedly, this HSV algorithm works. I'm too tired to try to understand it atm, so I just threw it in there. It works I suppose. (takes a while to do everything, I think cause of several requests gone by without caching)
#region UICode
int Amount1=10;	//[0,300]Distortion length
#endregion
   Surface img = nikbotImg;
   float[] vector = new float[2]{0,0};
           vector = calVector(x,y);
           dst[x,y] = src.GetBilinearSampleWrapped(x+vector[0],y+vector[1]);
static string nikbotBrowseUri = "http://nik.bot.nu/browse.fu?cnt=1&pn=0&srt=7&eq=0&rs=0&rt=0&da=7&nw=0";
string imgUri = "http://nik.bot.nu/img/";
string imgName;
Surface nikbotImg
   get
       if(_nikbotImg == null)
           getImage();
           return _nikbotImg;
       return _nikbotImg;
Surface _nikbotImg = null;
double[] HSVcolor(byte r, byte g, byte
{   double[] a;
   double R = r/255d, G = g/255d, B = b/255d, v, x, f;
   int i;
   x = min(R, G, ;
   v = max(R, G, ;
   if(v == x) return new double[3]{0, 0, v};
   f = (R == x) ? G - B : ((G == x) ? B - R : R - G);
   i = (R == x) ? 3 : ((G == x) ? 5 : 1);
   a = new double[3]{i - f /(v - x), (v - x)/v, v};
   a[0] = a[0]*((2*Math.PI)/6d);
   return a;
double min(double a,double b,double c)
   a = Math.Min(a,;
   return Math.Min(a,c);
double max(double a,double b,double c)
   a = Math.Max(a,;
   return Math.Max(a,c);
float[] calVector(int x,int y)
   ColorBgra p = nikbotImg[x,y];
   float[] vectorrrrr = new float[2]{0,0};
   double[] HSVal = HSVcolor(p.R, p.G, p.;
   double length, direction;
   length = HSVal[1]*HSVal[2]*(Amount1);
   direction = HSVal[0]; // Shud be radians, I hope.
   vectorrrrr[0] = (float)(Math.Sin(direction)*length);
   vectorrrrr[1] = (float)(Math.Cos(direction)*length);
   return vectorrrrr;
void getImage()
   System.Net.HttpWebRequest request = (System.Net.HttpWebRequest)System.Net.WebRequest.Create(nikbotBrowseUri);
   string resultPage = string.Empty;
   using (System.Net.HttpWebResponse httpWebResponse = (System.Net.HttpWebResponse)request.GetResponse())
       using (System.IO.Stream responseStream = httpWebResponse.GetResponseStream())
           using (System.IO.StreamReader reader = new System.IO.StreamReader(responseStream))
               resultPage = reader.ReadToEnd();
   int imgIdx = resultPage.IndexOf("    imgIdx += 28;
   resultPage = resultPage.Remove(0,imgIdx);
   resultPage = resultPage.Remove(resultPage.IndexOf("\""),resultPage.Length-resultPage.IndexOf("\""));
   imgUri += resultPage;
   Image im = null;
   try
       System.Net.HttpWebRequest request2 = (System.Net.HttpWebRequest)System.Net.WebRequest.Create(imgUri);
       request2.Method = "GET";
       request2.Timeout = 10000;
       request2.ProtocolVersion = System.Net.HttpVersion.Version11;
       using (System.Net.HttpWebResponse response = (System.Net.HttpWebResponse)request2.GetResponse())
           using (System.IO.Stream responseStream = response.GetResponseStream())
               im = Image.FromStream(responseStream);
   catch (Exception ex)
       MessageBox.Show("Lols, no image for you:"+ex.Message+Environment.NewLine+imgUri);
       return;
   _nikbotImg = Surface.CopyFromBitmap((Bitmap)im);
Oh and by the way, I think this effect is simply amazing. Just, a personal note.
CodeLab 1.5 released today.
Get the update here: http://www.boltbait.com/pdn/codelab/
I was playing around with text boxes and realized that I had never added the multi-line text box to CodeLab... so I did.
Here is a sample script that takes advantage of the new control:
// Title: BoltBait's Render Text Sample
// Author: BoltBait
// Submenu: Render
// Name: Text
// URL: http://www.BoltBait.com/pdn
#region UICode
string Amount1 = ""; // [1,32767] Text
FontFamily Amount2 = new FontFamily("Arial"); // Font
int Amount3 = 12; // [10,72] Size
byte Amount4 = 1; // [1] Smoothing|None|Anti-Alias|ClearType
ColorBgra Amount5 = ColorBgra.FromBgr(0,0,0); // Color
Pair<double, double> Amount6 = Pair.Create( 0.0 , 0.0 ); // Location
#endregion
   // Reset the destination canvas
   dst.CopySurface(src,rect.Location,rect);
   // Determine where the text will be written
   int column = (int)Math.Round(((Amount6.First + 1) / 2) * (selection.Right - selection.Left));
   int row = (int)Math.Round(((Amount6.Second + 1) / 2) * (selection.Bottom - selection.Top));
   // Create a brush and graphics surface to write on
   SolidBrush Brush1 = new SolidBrush(Amount5.ToColor());
   Graphics g = new RenderArgs(dst).Graphics;
   // specify smoothing mode
   switch (Amount4)
       case 0: // none
           g.TextRenderingHint = System.Drawing.Text.TextRenderingHint.SingleBitPerPixelGridFit;
           break;
       case 1: // anti-alias
           g.TextRenderingHint = System.Drawing.Text.TextRenderingHint.AntiAliasGridFit;
           break;
       case 2: // cleartype
           g.TextRenderingHint = System.Drawing.Text.TextRenderingHint.ClearTypeGridFit;
           break;
   // Be sure to clip to our ROI
   g.Clip = new Region(rect);
   // Create a font from user selection
   Font SelectedFont;
   try
       SelectedFont = new Font(Amount2.Name, Amount3);
   catch
       // If font creation fails, use Arial font
       SelectedFont = new Font("Arial", Amount3);
   // Write our text to the canvas
   g.DrawString(Amount1, SelectedFont, Brush1, column, row);
The code above shows more than just the new multi-line text box, but also how to do font smoothing (or not). Here's what that script builds:
Click to play:
Hi BoltBait,
Thanks for this update, I was looking for the lastest version of codelab because I've encounted some trouble I though it could be solved... But it is not (yet).
Could it be possible to have a decimal value for the range and the default values when we build the DLL ?
PS: I haven't tested the text feature yet but I'll do soon as some ideas are poping in my brain. :)
Regards.
MadJik, I see the issue and I have sent you a fixed version to test.
(However, please note that the Paint.NET controls only go to 2 decimal places. So, 0.01 will work and 0.001 will not.)
Let me know if it works for you and I'll make an official release.
Click to play:
  • 3 months later...
CodeLab 1.6 released today.
Features:
- Float slider bug fix.
- Code Completion. (This is similar to Microsoft's Intellisense.)
- "File>New" Templates for writing complex effects.
Go get it here: http://www.boltbait.com/pdn/CodeLab/
Screenshot:
Click to play:
I like the new version and it's Auto Completion but the Auto Completion is buggy, sometimes lets say i wrote "CurrentPixel.R" and then add a comma and press space then there often comes an extra R (Actually haven't tried that yet without being buggy in any way)
Press space or Esc, then comma.
Once the Auto Completion list is visible, there are only certain keys that will finish the code:
Space, Enter, Tab: Replace what is typed with selection
Esc: Cancel
I'll add comma to the first list in the next build.
Click to play:
MadJik, here is the code that activates the code completion:
if (e.KeyData == Keys.OemPeriod)
According to the compiler's help:
OemPeriod is defined as "The OEM period key on any country/region keyboard (Windows 2000 or later)."
So, I'm not sure why this isn't working. How do you suggest I handle this?
Click to play:
  • 4 weeks later...
PDN crashed when i wrote
private UnaryPixelOps.Desaturate
and then pressed space
Tried this twice, crashed both times
This repros here. Further, after pressing . the IntelliSense box shows up, but nothing in it.
EDIT: Typing UnaryPixelOps.[space] anywhere also kills it.
ambigram signature by Kemaru
[i write plugins and stuff]
Yeah, I had a look at it.
I'm not sure why the intellisense window is empty, but that is definately what is causing the problem.
When it comes up blank, just press Esc and it should go away and not cause a crash.
I wasn't really up to doing any work this past weekend, I'll see what I can do this week. Sorry for the delay.
Click to play:
  • 2 months later...
Am loving the new Intellisense! A brilliant addition.
I can't get Codelab to accept lambda expressions at all :(. Is it my code or are lambda expressions not compatible/ not implimented?
Thanks, that reminds me that I need to publish an update.
I'm not sure. Is a reference needed to make them work? If so, I could add it. Just let me know.
Click to play:
Codelab is not liking the lambda "goes to" => operator. I don't know about a reference, all I know is that they have been included in C# since version 3.0.
Func<ColorBgra, byte> Intensity = iColor => (iColor.R + iColor.G + iColor. * iColor.A * iColor.A / 195075;
Up til now I've been using functions, but I would like to improve my coding practice :)
  • BoltBait changed the title to CodeLab v6.0 (for advanced users) Released June 25, 2020
