Rick Brewster
CodeLab v5.4 (for advanced users) Released May 21, 2020
CodeLab 2.21 Released
Small update today...
Changes:
Fixed bug in the Build to DLL screen when using Rich Text help files. (toe_head2001)
▪ Modified updater code to defeat caching. (BoltBait)
Grab the CodeLab DLL here:
Thanks to ReMake for the bug report!
Share this post
Link to post
CodeLab 2.21 in Russian
You can find the new version of CodeLab in Russian here.
Вы можете найти новую версию CodeLab на русском языке здесь.
  • Upvote 2
Share this post
Link to post
Greetings everyone, as mentioned previously, CodeLab's "intelligent assistance" now has support for user defined Types.
This will work with any kind of Type (class, struct, enum, ect.) you create within your CodeLab script.
Here's some screenshots with @MJW's NormalMap script loaded. The user defined Type is Float4; a struct.
Spoiler
Since it now recognizes Float4 as a Type, normal is now in turn recognized as a variable.
Object Highlight, and also IntelliTip:
Static members:
Non-Static (instance) Members:
Constructors:
Type autocomplete:
  • Like 2
  • Upvote 2
Share this post
Link to post
CodeLab 2.22 Released
Changes:
Added Dark Theme (see View menu). (toe_head2001)
▪ "Intelligent assistance" now has support for user defined Types. (toe_head2001)
▪ Made building source code easier (see Readme.rtf in source code for details). (BoltBait)
  • Like 2
  • Upvote 2
Share this post
Link to post
Dark theme is cool, but I - beam cursor is hard to see.
Should it be white or yellow maybe?
Thank you for your effort.
Share this post
Link to post
I think you mean the text caret (the blinking line at the text insertion point).
I agree, it is difficult to see. I should have noticed that. :roll:
I'll change the color.
Share this post
Link to post
CodeLab 2.22 in Russian
Share this post
Link to post
Fixed.  Dark theme cursor is now "off white."
CodeLab 2.23 Released
Changes:
Fixed Dark Theme. (BoltBait)
▪ Added a few more templates into the File > New screen. (BoltBait)
  • Upvote 2
Share this post
Link to post
I've wanted a MRU menu in CodeLab for a long time, and last night, enough was enough. :lol:
It can even find the associated icon (if it exists) and the effect name from within the file (if it exists).
  • Like 2
  • Upvote 3
Share this post
Link to post
Sorry for asking, i'm currently using the portable version of Paint.NET, and of course the installer will not recognize any Paint.NET installation. Could you provide the DLL instead of the zipped EXE (installer) file?
Share this post
Link to post
31 minutes ago, xod said:
I do not know if anyone else noticed this, but CodeLab 2.24 does not correctly pinpoint the errors.
Is that how it should behave?
Yes, I made a typo when making some changes. Sorry. The column is not getting set correctly, so the position of the red underline goes to the previous line.
I've already fixed this, and I will coordinate with BoltBait once I've finished with some other improvements I'm working on.
  • Like 2
Share this post
Link to post
21 minutes ago, xod said:
CodeLab and PDN crash if we modify the version as in the image and try to build the dll.
Yeah, those two values need to be clamped; which I have just done. Easy peasy.
MajorVersion.Value = majorv.Clamp(MajorVersion.Minimum, MajorVersion.Maximum);
Share this post
Link to post
Hi,
I'm having trouble with radiobuttons (same for dropdownlist).
In CodeLab I can change the value in the UI part of the code
RadioButtonControl Amount6 = 4; // [1] Shadow|None|Black|White|White+Black|Black+White
Once built the Radiobutton is set to 0 ('None')
Share this post
Link to post
Howdy, I've fixed this for the next release.
However, anytime you use the UI Designer, it will revert the number back to 0 in your script. You'll need to make sure it's correct before building a DLL.
Share this post
Link to post
I found some time to hack away on CodeLab during the past few days, and I have a few new features brewing.
Behold, a new 'Find & Replace' floating panel.
Spoiler
Available find options are:
- Match Casing
- Match Whole Word
- Use Regex
- Interpret Escape Characters
And expanded for Replacing:
Share this post
Link to post
