Project Mascot
I recently registered an open source project called NalaCAD on sourceforge. I have been working on some code with regards to it for some time and had an idea for a mascot that I had been putting of creating. Well after drawing the outline with InkScape and coloring it with Paint.NET, meet Nala. Critiques, suggestions, whatever. Thanks for a great tool. I love the gradients, as you can tell.
http://nalacad.blogspot.com/
Not bad.
I'm not a drawer nor CAD user nor archi.
I would just suggest you to use circle gradient instead square gradient for face and body (it creates some kind of cross : bad effect IMO).
Also perhaps place the pen and ruler on 'hands' (not under)...
The link for the name Nalacad isn't a direct link... Why should we use the search tool?
BTW I'm looking forward to test your soft...
Thanks, Yeah, I will give circle gradient a try. I have a feeling this will go thru a lot of variations, but I just wanted to get something out there.
Oh, as for the direct link about the name. I initially tried to get it from wikipedia, but the wiki link kept diverting me. Weird.
