Dudmaster Posted November 27, 2013 Share Posted November 27, 2013 I need help. I cannot uninstall Paint.NET from m computer. I get this error: It appears I need the uninstaller package. How do I fix this? -Dud Quote Link to comment Share on other sites More sharing options...
Siltriz Posted December 7, 2013 Share Posted December 7, 2013 Mismo problema! y sin respuesta... Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 7, 2013 Share Posted December 7, 2013 English please. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
venue Posted December 11, 2013 Share Posted December 11, 2013 I'm having the same problem, running v3.5.10 on an old XP laptop.OP posted in english, too. just for what that's worth. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted December 11, 2013 Share Posted December 11, 2013 Have you seen this thread: http://forums.getpaint.net/index.php?/topic/692-install-update-or-uninstall-trouble-read-this/ Read through the entire thread then return to the second post which mentions the Windows Installer CleanUp utility. That should take care of the remains of 3.5.10 for you. Q: have you tried installing 3.5.11 over the top of 3.5.10? The later version automatically handles the removal of the former version Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Dudmaster Posted December 23, 2013 Author Share Posted December 23, 2013 (edited) The version I have the problem with is the latest. I'll try waiting for the next update, but reinstalling didn't work. I'll check out the CleanUp utility. EDIT: I have Windows 8, the utility doesn't support it. 2ND EDIT: The Spanish dude said "Same problem! No response..." Edited December 24, 2013 by Dudmaster Quote Link to comment Share on other sites More sharing options...
