Best way to remove White backround / noise from Large Drawing?
I have rather large blueprint that is black and white. Their is some noise around some of the black lines / text / etc on the drawing that I want to get rid of as well as get rid of the white back round all together (which I am hoping will reduce the file size a bit).
Any ideas on how to best remove the white backround / remove the noise from this large drawing?
Found the global mode in the Flood Mode drop down.
Global mode shortcut is to hold down the Shift key when making a selection or fill ;)
