iluvmyogdexter Posted January 13, 2011 Share Posted January 13, 2011 (edited) Hey there I've been looking around for the right plug in, and since I couldn't find one, I decided to make an account and ask the people who know the program the best. You guys So I know a person that uses paint.net, and I asked them what plug ins they used . . . they said I had to "be resourceful" and "figure it out" so, I guess I'm doing that . . . the picture below is what I want to figure out what they used for. I mostly want to figure out how to do the stars, and see the pets? I want to figure out how to get them in the boxes like that . . . that's about it I guess Edited January 13, 2011 by iluvmyogdexter Quote Link to comment Share on other sites More sharing options...
Tarat Posted January 13, 2011 Share Posted January 13, 2011 Hm...It's a small picture and I can't see well, but IMHO, it looks as if the stars are photoshop brushes. For that, you'll need "Custom Brushes Mini" and this program(to open the brushes)...You can download them from a bunch of places...Personally, I use deviantart. You can search around and find similar brushes. Although...it's possible to get a similar effect with pyrochild's "Random Shape Fill" Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 13, 2011 Share Posted January 13, 2011 The fonts Wingdings1 & Wingdings2 both have stars that you can use as parts of your image. I'm sure there are many more fonts that also have stars. Download and install the WhichSymbol+ plugin (link in my signature), help on plugin installation here: how to install plugins...,. Simply create a new layer :AddNewLayer: above your image and then go to the Effects menu, submenu Render & click on the WhichSymbol entry. Select the font and character you want and press OK. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Tarat Posted January 13, 2011 Share Posted January 13, 2011 Or that. ...And it requires less downloading...lol...(CustomBrushesMini is still a good plugin to have though:D) Quote Link to comment Share on other sites More sharing options...
iluvmyogdexter Posted January 13, 2011 Author Share Posted January 13, 2011 Thanks for all the help I'll try out all the suggestions and get back to you guys (sorry the picture was so small, I used a profile picture ) Quote Link to comment Share on other sites More sharing options...
