My sigs and stuff
I used a downloaded font but looking at it now I think I should have used the line tool cause they look kinda sketchy. Any way downloaded font in blue then gaus. blur a bit ;) I would give you a link to the font but I cant remember where I got it from, sorry. I can however give you a link to a great free font site:
dafont.com
Thanks for all the comps. guys
^Click to visit my Flickr Gallery^
the button is easy... fill a circle selection with a grey-to-grey gradient, then do another circle selection (smaller) and fill it with another grey-to-grey gradient,
then do another circle selection and fill it with Dark Horizontal fill style (green and black)
EDIT: the button needs some radial blurs...
this is what i got the idea from:
oh, and instead of filling another circle with a grad. you could just select a small part of the existing cirlce and invert the selection ;)
Poo87 is my username at another forum(don't ask) and when you do a google image search for poo87 it brings up a pic of the girl in the sig so i decided to use her as a render in that sig :P
I sometimes remember numbers in binary, decimal, octal, and hex!
My birthday is 1024 or 10000000000 or 400 or 2000. Pretty, neat, huh?
I'm sure Chris has firefox, and/or links it to "Random".
I happen to remember special parts of the ascii extended table (decimal for Alt codes), like:
á - 160
é - 130
í - 161
ó - 162
ú - 163
ç - 135
è - 138
Greek letters start at 224.
Mathematical constants are my specialty, with Pi, e...
And to everybody, I would refer to the Windows Bliss Parody forum to see my latest one(s).
