ZenDisaster Posted March 1 Share Posted March 1 I've looked all over for an explanation on the differences between BC5 (Linear, Unsigned) and BC5 (Linear, Unsigned, AT12). Would someone please kindly enlighten me? I'm very new to all this and can't seem to find any information on AT12 when I google. Quote Link to comment Share on other sites More sharing options...
Solution null54 Posted March 1 Solution Share Posted March 1 5 hours ago, ZenDisaster said: I've looked all over for an explanation on the differences between BC5 (Linear, Unsigned) and BC5 (Linear, Unsigned, AT12). Would someone please kindly enlighten me? I'm very new to all this and can't seem to find any information on AT12 when I google. The only difference between those two formats is the file header value used to identify it. ATI2 is one of the legacy names for BC5, which some applications require instead of the BC5U value that the BC5 (Linear, Unsigned) format uses. 1 1 2 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
ZenDisaster Posted March 2 Author Share Posted March 2 Thank you! I really appreciate you taking the time to answer my question. Quote Link to comment Share on other sites More sharing options...
