Fagon Viendra Posted January 19 Share Posted January 19 CPU always reaches 80 to 90 percent. How to fix that? Thank you. Quote Link to comment Share on other sites More sharing options...
Tactilis Posted January 19 Share Posted January 19 1. Are you able to Cancel the save or is paint.net completely unresponsive now? 2. Is this the first time you have had this happen, or is it repeatable if you load the same .jpg or .png and save to AVIF again? If it is repeatable, please upload the offending image to https://postimages.org/ (for example) and post the link. 3. Does the same problem occur if you set the Quality back to the default value, instead of 100%? 4. Does the same problem occur if you set the Encoder Preset back to Fast? 1 Quote Link to comment Share on other sites More sharing options...
null54 Posted January 19 Share Posted January 19 7 hours ago, Fagon Viendra said: CPU always reaches 80 to 90 percent. How to fix that? This is a known issue with the AVIF plugin. The fix is to not use the Very Slow preset. The Very Slow preset instructs AOM to encode the image using the slowest compression, without chopping it up into a sequence of smaller frames. This usually provides the smallest file size, but it is not a great user experience due to the limited opportunities for progress reporting and cancellation. 7 hours ago, Tactilis said: 1. Are you able to Cancel the save or is paint.net completely unresponsive now? Paint.NET will stop responding until AOM finishes its encoding. The plugin only reports progress and allows cancellation before and after AOM compresses a frame. 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Fagon Viendra Posted January 20 Author Share Posted January 20 Thank you everyone, now I understand. The very slow preset is really a problem here. I hope to be able to fix that one day soon. Quote Link to comment Share on other sites More sharing options...
Tactilis Posted January 20 Share Posted January 20 1 hour ago, Fagon Viendra said: The very slow preset is really a problem here Do you really need to use that preset? Have you done a comparison of file sizes between Fast, Medium, Slow, and Very Slow? Depending on the nature of your image, you might find that you are saving little, or even nothing, between Very Slow versus Slow or Medium. Also, what is the end use of your image? Does it demand that the quality to be set to 100%? You seem to have set everything to the maximum. If you back off from that a little, you will have much faster encoding. 1 Quote Link to comment Share on other sites More sharing options...
Fagon Viendra Posted January 20 Author Share Posted January 20 16 minutes ago, Tactilis said: Also, what is the end use of your image? Does it demand that the quality to be set to 100%? I want everything to be perfect but still optimized and up-to-date. 18 minutes ago, Tactilis said: Depending on the nature of your image, you might find that the you are saving little, or even nothing, between Very Slow versus Slow or Medium. 17 minutes ago, Tactilis said: You seem to have set everything to the maximum. If you back off from that a little, you will have much faster encoding. Thank you for your advice. Quote Link to comment Share on other sites More sharing options...
