Arman Posted January 27 Share Posted January 27 (edited) Hi. I used Paint.net to do a map . I did this map for 7 days, today I just wanted to resize it. I did it, but I did not notice that this ruined my work and I saved it. Now I have a project , that is little bit smoothing , it is still usable, but I don't like it and I would want to fix this and make my map clean , not smoothy again. Is there any way to do it? Edited January 27 by Arman needed to add a normal image Quote Link to comment Share on other sites More sharing options...
BlastOfBN Posted January 27 Share Posted January 27 What kind of sampling did you use to size up your image? I need to know so I can come up with some solutions. Quote Link to comment Share on other sites More sharing options...
Arman Posted January 28 Author Share Posted January 28 Do you mean how I did that? I clicked at "Image", then "Resize", and removed only 6 pixels from the nubmer. Also I think I clicked off the "aspect ratio" or "absolute size" in the same place. (I hope I understood the question right) Quote Link to comment Share on other sites More sharing options...
BlastOfBN Posted January 28 Share Posted January 28 @Arman I was referring to the resampling feature that appears in the resize menu. Do you remember which one you used? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 28 Share Posted January 28 Find your image file using File Explorer. Right click > Restore previous versions might give you an option. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Arman Posted January 28 Author Share Posted January 28 @BlastOfBN hm.. I did not changed that, so I think it is the first one , because I did not do anything with that 8 hours ago, BlastOfBN said: Quote Link to comment Share on other sites More sharing options...
Arman Posted January 28 Author Share Posted January 28 I will try to restore the savefile like that Quote Link to comment Share on other sites More sharing options...
Arman Posted January 28 Author Share Posted January 28 (edited) @Ego Eram ReputoIt did not work... It did not found any save files. Edited January 28 by Arman Quote Link to comment Share on other sites More sharing options...
Solution Arman Posted February 11 Author Solution Share Posted February 11 Ok, I just decided to to everything from the start, but as advice, be careful , be not like me . Quote Link to comment Share on other sites More sharing options...
