Not a pro.. but approved images is topice..
14 minutes ago, jodooley said:
how do I apply changes to an image and retain the image then on my own?
This depends on what changes you want to make.  Once you have what you want, then flatten the image and use Save As and pick whatever 'type' you want.  Png retains transparency, or you can Save As a jpeg.
If you are a new user to Paint.net I would suggest doing some of the tutorials, which is the only way to learn :)
2 minutes ago, jodooley said:
I do not know code?
You only need to know code if you want to make a Plugin.  If you want to alter an image, you need to tell us what exactly you want to do with it, before we can help you.
2 hours ago, jodooley said:
I have permission to use and image.. how do I apply changes to an image and retain the image then on my own?
Bring the image into Paint.NET. Then select 'Save As' and create a new name for the file before saving.
This will leave the original image in tact and you can work on the renamed copy
