Reptillian Posted December 9, 2019 Share Posted December 9, 2019 (edited) I have this code right here I have made out of trying something new. And I find that there doesn't seem to be a easy way to preserve 0,255 ranges on Divisive Modulo. // Name: Image Modulo Toolkit // Submenu: Adjustments // Author: Reptorian // Title: Image Modulo Toolkit // Version: .5 // Desc: Adjust image values based on the logics of Krita Modulo Blending Modes, or G'MIC 'modf' or 'modular_formula'. // Keywords: // URL: // Help: #region UICode ListBoxControl Amount1 = 0; // Blending Mode | Modulo | Modulo Continuous | Divisive Modulo IntSliderControl Amount2 = 255; // [1,255] Maximum Number #endregion void Render(Surface dst, Surface src, Rectangle rect) { // Delete any of these lines you don't need Rectangle selection = EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt(); int CenterX = ((selection.Right - selection.Left) / 2) + selection.Left; int CenterY = ((selection.Bottom - selection.Top) / 2) + selection.Top; ColorBgra PrimaryColor = EnvironmentParameters.PrimaryColor; ColorBgra SecondaryColor = EnvironmentParameters.SecondaryColor; int BrushWidth = (int)EnvironmentParameters.BrushWidth; ColorBgra CurrentPixel; for (int y = rect.Top; y < rect.Bottom; y++) { if (IsCancelRequested) return; for (int x = rect.Left; x < rect.Right; x++) { CurrentPixel = src[x,y]; int R = (int)CurrentPixel.R; int G = (int)CurrentPixel.G; int B = (int)CurrentPixel.B; float DivMult= 255/Amount2; switch(Amount1) { case 0: R=(byte)(R%(Amount2+1)); G=(byte)(G%(Amount2+1)); B=(byte)(B%(Amount2+1)); break; case 1: int TR=R/(Amount2+1); int TG=G/(Amount2+1); int TB=B/(Amount2+1); bool CR=TR%2==1; bool CG=TG%2==1; bool CB=TB%2==1; if (CR) {R=(byte)(Amount2-(R%(Amount2+1)));} else {R=(byte)(R%(Amount2+1));} if (CG) {G=(byte)(Amount2-(G%(Amount2+1)));} else {G=(byte)(G%(Amount2+1));} if (CB) {B=(byte)(Amount2-(B%(Amount2+1)));} else {B=(byte)(R%(Amount2+1));} break; case 2: float MTR=R%(Amount2+1); float MTG=G%(Amount2+1); float MTB=B%(Amount2+1); MTR*=(float)(DivMult); MTG*=(float)(DivMult); MTB*=(float)(DivMult); int NMTR = (int)(MTR); int NMTG = (int)(MTG); int NMTB = (int)(MTB); R=(byte)(NMTR); G=(byte)(NMTG); B=(byte)(NMTB); break; } CurrentPixel = ColorBgra.FromBgra((byte)(B),(byte)(G),(byte)(R),CurrentPixel.A); dst[x,y] = CurrentPixel; } } } I know the case 2 could be simpler, but haven't really figured it out. Edited December 10, 2019 by Reptillian Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 9, 2019 Share Posted December 9, 2019 16 minutes ago, Reptillian said: And I find that there doesn't seem to be a easy way to preserve 0,255 ranges on Divisive Modulo. If you need to clamp the RGB values, you can do this: CurrentPixel = ColorBgra.FromBgraClamped(B, G, R, CurrentPixel.A); Or did I misunderstand your question? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Reptillian Posted December 9, 2019 Author Share Posted December 9, 2019 (edited) 6 minutes ago, toe_head2001 said: If you need to clamp the RGB values, you can do this: CurrentPixel = ColorBgra.FromBgraClamped(B, G, R, CurrentPixel.A); Or did I misunderstand your question? You misunderstood. If you use 175 for Divisive Modulo, you'd note that the highest value is not 255, and the expected value is 255. While you shift value, it should behave similar to the first 2 modulo modes. That didn't really work as a solution. Edited December 9, 2019 by Reptillian Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 9, 2019 Share Posted December 9, 2019 CodeLab has Debug Output capabilities; I suggest you use it. Click on the associated Checkbox at the bottom of CodeLab. For example, if you want to evaluate your math expressions, you can do this: void PreRender(Surface dst, Surface src) { int R = 255; float DivMult = 255 / Amount2; Debug.WriteLine("DivMult: " + DivMult); float MTR = R % (Amount2 + 1); Debug.WriteLine("MTR: " + MTR); MTR *= (float)(DivMult); Debug.WriteLine("MTR: " + MTR); int NMTR = (int)(MTR); Debug.WriteLine("NMTR: " + NMTR); R = (byte)(NMTR); Debug.WriteLine("R: " + R); } 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
MJW Posted December 10, 2019 Share Posted December 10, 2019 I don't know if this will solve the problem you're referring to, but I doubt this line does what you want it to do: float DivMult= 255/Amount2; Amount2 is an int, as is 255, so an integer divide will be performed, and the (integer) result converted to a float. I suspect that's not what's intended. Try: float DivMult= 255.0 / (float)Amount2; (Also, the line should be moved outside the loop. It can be computed once at the top.) 1 Quote Link to comment Share on other sites More sharing options...
Reptillian Posted December 10, 2019 Author Share Posted December 10, 2019 I should have mentioned I solved It. Anyways, when I was coding that, I realized that when coding for c#, it is not like c++ or the gmic scripting language and did not taken the account for the need of converting Amount2 into a float. I knew that I have to work with converting types. It was fun doing something different once in a while. Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
MJW Posted December 10, 2019 Share Posted December 10, 2019 3 hours ago, Reptillian said: I realized that when coding for c#, it is not like c++ C++ does the same thing as C#. Both treat a division of two ints as an integer division, as does C. Quote Link to comment Share on other sites More sharing options...
Reptillian Posted December 10, 2019 Author Share Posted December 10, 2019 24 minutes ago, MJW said: C++ does the same thing as C#. Both treat a division of two ints as an integer division, as does C. I have checked, and yes you're correct. It seems that I have forgotten some fair bit of c++ after not using it in a while. Quote G'MIC Filter Developer Link to comment Share on other sites More sharing options...
