xolbor Posted November 24, 2018 Share Posted November 24, 2018 I had to recently format my computer due to some problems in my corrupted user profile so i had to get all my old programs from scratch. Paint.net used to run perfectly without any issues. Later today , after i installed the program , ive noticed some rendering lag when using the recolour tool. Ive tried disabling hardware acceleration but it didnt work. Does anyone have a fix for it? Quote Link to comment Share on other sites More sharing options...
LionsDragon Posted November 25, 2018 Share Posted November 25, 2018 Ugh, reformatting is the worst. I feel your pain. What version of Paint.Net are you using? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted November 25, 2018 Share Posted November 25, 2018 Can you provide us with some details about your system? Settings -> Diagnostics -> Copy to clipboard Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 25, 2018 Share Posted November 25, 2018 If you have an NVIDIA GeForce and are using GSync, make sure GSync's "windowed mode" is not enabled. It really doesn't work, and it completely janks up the framerate for apps like Paint.NET. Only enable GSync in "fullscreen" mode. (This setting is in the NVIDIA control panel.) Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
xolbor Posted November 25, 2018 Author Share Posted November 25, 2018 (edited) 16 hours ago, toe_head2001 said: Can you provide us with some details about your system? Settings -> Diagnostics -> Copy to clipboard Application paint.net v4.1.4 (Final 4.104.6882.34660) Build Date domingo, 4 de novembro de 2018 Install type Classic Acelerada por hardware (GPU) de renderização True Animações True DPI 96,00 (1,00x scale) Idioma pt-BR OS Windows 10 Pro x64 (10.0.17763.0) (0x30) .NET Runtime 4.0.30319.42000 Physical Memory 6.127 MB CPU AMD FX(tm)-6300 Six-Core Processor Speed ~3516 MHz Cores / Threads 3 / 6 Features DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVE Video Card ATI Radeon HD 4550 Dedicated Video RAM 503 MB Dedicated System RAM 0 MB Shared System RAM 2.816 MB Vendor ID 0x1002 Device ID 0x9540 Subsystem ID 0x02981043 Revision 0 LUID 0x00007A16 Flags SupportNonMonitoredFences Graphics Preemption DmaBufferBoundary Compute Preemption DmaBufferBoundary Outputs 1 Feature Level Direct3D_10_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 3.063 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x00008B3F Flags Software, AcgCompatible, SupportMonitoredFences, SupportNonMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Edited November 25, 2018 by xolbor Quote Link to comment Share on other sites More sharing options...
xolbor Posted November 25, 2018 Author Share Posted November 25, 2018 16 hours ago, LionsDragon said: Ugh, reformatting is the worst. I feel your pain. What version of Paint.Net are you using? The latest one downloaded from the paint.net site Quote Link to comment Share on other sites More sharing options...
xolbor Posted November 25, 2018 Author Share Posted November 25, 2018 3 hours ago, Rick Brewster said: If you have an NVIDIA GeForce and are using GSync, make sure GSync's "windowed mode" is not enabled. It really doesn't work, and it completely janks up the framerate for apps like Paint.NET. Only enable GSync in "fullscreen" mode. (This setting is in the NVIDIA control panel.) I dont have a NVIDIA Graphics card Quote Link to comment Share on other sites More sharing options...
