Please help with "Kill Color Keeper" plugin.
Hi Everyone,
Being a beginner I know next to nothing about programming and I am trying to achieve something.
Here, I wanted to make amendment in UI for Kill color Keeper like this. This was to include dropdown from Jotaf's original plugin.
Previous UI was.
In UI region I Added,
#region UICode
DoubleSliderControl Amount1 = 1; // [0,20] Color tolerance:
ColorWheelControl Amount2 = ColorBgra.FromBgr(0,0,0); // [PrimaryColor] {!Amount3} Select Color
CheckboxControl Amount3 = false; // [0,1] Use specific Values to Select Colors
ListBoxControl Amount4 = 0; // {Amount3} What Color?|What color?|Primary Color|Secondary Color|White|Gray|Black
RadioButtonControl Amount5 = 0; // [1] Functions|Keep Color|Kill Color
IntSliderControl Amount6 = 0; // [0,255] Consider transparent any alpha smaller than:
IntSliderControl Amount7 = 255; // [0,255] {Amount5} Consider transparent any alpha greater than:
#endregion
And for assigning input color value I updated this line
ColorBgra color = Amount2;
into this block of codes.
ColorBgra color;
    if(Amount3)
        color = Amount2;
    else
      //selecting things from dropdown
        switch(Amount4)
            case 0: // Primary color
                color = (ColorBgra)EnvironmentParameters.PrimaryColor;
                break;
            case 1: // Secondary color
                color = (ColorBgra)EnvironmentParameters.SecondaryColor;
                break;
            case 2: // White
                color = ColorBgra.White;
                break;
            case 3: // Gray
                color = ColorBgra.Gray;
                break;
            default: // Black
                color = ColorBgra.Black;
                break;
So, In UI output is as expected, for the drop-down & Color-Wheel are enabled and disabled and working as expected. But somehow the selection of color is not working at all.
i.e. The behavior is I am seeing.
  • When checkbox for "specific values" is checked, Dropdown is enabled as expected, I can choose color from dropdown but Output for the selected Color from dropdown doesn't reflect on Canvas.
  • When checkbox for "specific values" is uncheckedColorWheel is  enabled as expected, I can change value for color but Again output for the selected Color from ColorWheel doesn't reflect on Canvas.
UI is eternally struck on Primary Color which is default value. If I comment the whole "if else and switch" block of new code,  and replace it with simply "ColorBgra color = Amount2;" every thing starts working again magically. How to make the it work?  I am at my wit's end and I can't understand what is happening here. :cry::cry::cry:.
Here is the full code.:arrow-down:
Code:
Spoiler
// Name:Kill Color Keeper
// Submenu: Color
// Author: Pratyush
// Title: KillColorKeeper
// Version: 1.2.0
// Desc: Removes or Preserves a color while maintaining the alpha information
// Keywords: Color|Transparency|Alpha|Retention|Background
// URL:
// Help:
#region UICode
#endregion
//Kill Color Keeper by Pratyush
//Based on Original Grim Color Reaper by Jotaf
    //ColorBgra color;
    //if(Amount3)
    //    color = Amount2;
    //else
    //  //selecting things from dropdown
    //    switch(Amount4)
    //        case 0: // Primary color
    //            color = (ColorBgra)EnvironmentParameters.PrimaryColor;
    //            break;
    //        case 1: // Secondary color
    //            color = (ColorBgra)EnvironmentParameters.SecondaryColor;
    //            break;
    //        case 2: // White
    //            color = ColorBgra.White;
    //            break;
    //        case 3: // Gray
    //            color = ColorBgra.Gray;
    //            break;
    //        default: // Black
    //            color = ColorBgra.Black;
    //            break;
    //color as double
    double R = color.R, G = color.G, B = color.B;
    ColorBgra pixel;
    double rdif, gdif, bdif;
    double alpha;
            pixel = src[x,y];
            //difference between this pixel's color and the color to erase
            rdif = pixel.R - R;
            gdif = pixel.G - G;
            bdif = pixel.B - B;
            //simple way of figuring out the alpha: the more distant the colors,
            //the larger the alpha.
            alpha = Amount1 * Math.Sqrt(rdif*rdif + gdif*gdif + bdif*bdif);
            if (Amount5 == 1)
                if (alpha <= Amount6)  //alpha cut-off (fully transparent)
                    pixel.A = 0;
                else if (alpha < pixel.A)    //only apply change if it causes a pixel to become more
                {                            //transparent (to blend nicely with existing alphas)
                    pixel.A = (byte) alpha;
                    alpha = alpha / 255;  //normalize alpha to range 0..1
                    //we assume that each pixel is the result of linear interpolation between an
                    //unknown foreground color, and the user selected background color, which
                    //means it obeys the equation: (for each of Red, Green and Blue)
                    //  final = foreground*alpha + background*(1-alpha)
                    //we already figured out the alpha, so we just need to invert the equation
                    //to obtain the original foreground color:
                    //  foreground = (final - background*(1-alpha)) / alpha
                    pixel.R = Int32Util.ClampToByte((int) (((double) pixel.R - R*(1-alpha)) / alpha));
                    pixel.G = Int32Util.ClampToByte((int) (((double) pixel.G - G*(1-alpha)) / alpha));
                    pixel.B = Int32Util.ClampToByte((int) (((double) pixel.B - B*(1-alpha)) / alpha));
            else
              	if (Amount6 >= pixel.A)  //Ignore transparent pixels
                    pixel.A = 0;
                else if (alpha >= Amount7)  //alpha cut-off (fully opaque)
                    pixel.A = 0;
                else if (alpha > pixel.A)    //only apply change if it causes a pixel to become more
            dst[x,y] = pixel;
Thanks and Regards.
Edited by Pratyush
Look at this version of your code:
Spoiler
// Submenu: Color
// Author: Pratyush
// Version: 1.2.0
// URL:
// Help:
#region UICode
ColorWheelControl Amount2 = ColorBgra.FromBgr(0,0,0); // [PrimaryColor] {Amount3} Select Color
ListBoxControl Amount3 = 0; // {Amount3} What Color?|Custom|Primary Color|Secondary Color|White|Gray|Black
RadioButtonControl Amount4 = 0; // [1] Functions|Keep Color|Kill Color
IntSliderControl Amount5 = 0; // [0,255] Consider transparent any alpha smaller than:
IntSliderControl Amount6 = 255; // [0,255] {Amount4} Consider transparent any alpha greater than:
#endregion
    ColorBgra pixel;
    double alpha;
            ColorBgra color;
            if(Amount3==0)
            {color = Amount2;}
            else
            switch(Amount3)
                case 1: // Primary color
                    break;
                case 2: // Secondary color
                    break;
                case 3: // White
                    break;
                case 4: // Gray
                    break;
                case 5: // Black
                    break;
                default: // Custom
                    color = Amount2;
                    break;
            //color as double
            pixel = src[x,y];
            rdif = pixel.R - R;
            gdif = pixel.G - G;
            bdif = pixel.B - B;
            if (Amount4 == 1)
                if (alpha <= Amount5)  //alpha cut-off (fully transparent)
                    pixel.A = 0;
            else
              	if (Amount5 >= pixel.A)  //Ignore transparent pixels
                    pixel.A = 0;
                else if (alpha >= Amount6)  //alpha cut-off (fully opaque)
                    pixel.A = 0;
            dst[x,y] = pixel;
This my code is non-optimal. You need to analyse it and then to optimize.
