tbee Posted May 10, 2008 Share Posted May 10, 2008 I know I can apply an effect, like blur or darken, using a selection (e.g. rectangle). Is it also possible to apply effects using a brush? I would like to fade an edge. Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted May 10, 2008 Share Posted May 10, 2008 Try This: viewtopic.php?f=15&t=22096 Quote Link to comment Share on other sites More sharing options...
Vonbrucken Posted May 10, 2008 Share Posted May 10, 2008 Bookmarked for future reference Quote http://www.myspace.com/vonbrucken http://www.myspace.com/mutedesigner Link to comment Share on other sites More sharing options...
Mike Ryan Posted May 10, 2008 Share Posted May 10, 2008 *Cough* Quote Link to comment Share on other sites More sharing options...
Rubrica Posted May 10, 2008 Share Posted May 10, 2008 What was the point of that post, if I may ask, Mike? Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted May 10, 2008 Share Posted May 10, 2008 What was the point of that post, if I may ask, Mike? *cough* is usually a reference to something that already exists or will soon exist that the person isn't aware of. Quote Link to comment Share on other sites More sharing options...
Rubrica Posted May 10, 2008 Share Posted May 10, 2008 Oh. Sorry. I won't post things like that in the future, with my limited knowledge of technical... stuff. Quote Link to comment Share on other sites More sharing options...
tbee Posted May 10, 2008 Author Share Posted May 10, 2008 Oh. Sorry. I won't post things like that in the future, with my limited knowledge of technical... stuff. I didn't know that meaning of cough either (to me it usually denotes someone making a remark not to be taken seriously, or that someone has a cold). Anyhow, I think the multilayer approach is quite unpractical; maybe you need to do it a few times, but I simple want a "edge fader". However, I do understand the uforia about the workaround, because it makes stuff possible that are missed severly, but... personally... well... When is 4.0 due? :wink: Tom PS: what is 'the other free paint tool'? You can PM me Quote Link to comment Share on other sites More sharing options...
The_Lionhearted Posted May 10, 2008 Share Posted May 10, 2008 P.S. Try the "Fade Edge" effect...in the plugin section. viewtopic.php?f=16&t=22881 Quote My Gallery Link to comment Share on other sites More sharing options...
tbee Posted May 12, 2008 Author Share Posted May 12, 2008 P.S. Try the "Fade Edge" effect...in the plugin section. viewtopic.php?f=16&t=22881 Ah, not, "fade edge" is not what I want. My edge is mid-image. In fact it's an older image, canvas resized to 1920x1200 and I need to fade out the edge that became present now; some white/grey tints need to be blurred. Quote Link to comment Share on other sites More sharing options...
