Posted
yes totally odd right in the middle of a picture as well I might say. good thing it was only a practice of technique.
I closed out the paint.net program re started and the mouse was back to the left click. so odd
I've just tried to replicate and couldn't. must just have been a glitch with the combination of plugins.
the ones I was using on the test picture were multi gradiant, power stretch, drop shadow, rotate layers and then feather. so could have been any one of them or a combination of all.
very odd behaviour.
will mark it up as a glitch for now. and if it happens again will record exact steps.
so for now looks fine just strange.
Posted
Very, very odd. I'm going to toss this over to Troubleshooting; find it there if it happens again.
Posted
that is strange. I have seen something like this before in windows were you right click for a file menu and then when you left click the mouse keeps doing the right click action instead.
Posted
so I've been able to reproduce error twice now.
I'm posting a screen shot of what steps I've done at the eraser point it moves from left click to right click.
things I can think of that might help you all sort this out.
I ususally feather more than once and at high second number true feather. primary color is set at 0 alpha after feather I always magnify above 500 so I can see stray pixels.
I'm running 3.31 xp
closing and saving the pdn and just reopening does not revert my mouse clik back to left. I must discard the picture and start over.
I have had luck adding another layer and changing primary back to 255 alpha and using eraser with both right and left ? mouse buttons at that point.
very odd.
ciao OMA
Posted
Oma is your left click working all right for all other pdn tools except for eraser?
Cause I've encountered lots of troubles lately (i.e. when I left clicked the rectangle or ellipse tools they got weird while if I right clicked on them they worked all right) so I tried with a new mouse and the problem was fixed (may be my left click button was broken, I don't know)
