UFWHOA Posted April 20, 2008 Share Posted April 20, 2008 I was just thinking about it, since i don't have a dSLR camera to adjust aperture settings manually, how to create a convincing Bokeh effect. Does anybody have any ideas as far as various methods and plugins that would be great for creating realistic bokeh to a photo? I was even thinking about creating a "Bokeh" brush and use layer blend modes to apply the effect. Quote http://www.ufwhoa.deviantart.com/ Link to comment Share on other sites More sharing options...
Mike Ryan Posted April 20, 2008 Share Posted April 20, 2008 Use cutting out images the easy way to take out the portions of the image you want to remain sharp and then apply Fragment at a large distance. Quote Link to comment Share on other sites More sharing options...
Ash Posted April 20, 2008 Share Posted April 20, 2008 Plugins & Effects you need to try: Focal Point viewtopic.php?f=16&t=22919 Gradient Blur viewtopic.php?f=16&t=20884 Fragment effect- Built into the PDN3.30 and up. There will be a Lens blur later on too. Tutorials you should checkout: viewtopic.php?f=15&t=2756 viewtopic.php?f=15&t=4841 Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
UFWHOA Posted April 27, 2008 Author Share Posted April 27, 2008 just an update, I tried out the Erode/Dilate plugin effect and it works great. I'd have to tweak the photo to make it look more realistic as far as blending properly especially if I using just one photograph with the subject in it because the subjust spreads in the photo too, which ruins the depth-of-field effect. But this works excellent if taking a photograph of the subject and another of the background and applying the effect to the background and blending the subject smoothly into the background. But yeah, Erode/Dilate plugin looks pretty close to a "natural" bokeh. Quote http://www.ufwhoa.deviantart.com/ Link to comment Share on other sites More sharing options...
MiguelPereira Posted April 27, 2008 Share Posted April 27, 2008 There will be a Lens blur later on too. What? Quote [The stock on my sig is a photo I took not a render from Splatter] [My deviantART][My Gallery][My Space] Link to comment Share on other sites More sharing options...
