jmf1982 Posted January 10, 2008 Share Posted January 10, 2008 Hi, The other day I found a plugin (Conditional Hue/Saturation plugin) and I tried to add the project of this plugin but I don´t really know how to do it. I tried to use the DLL with the paint project but it didn´t work. Does anybody can help me??? I already tried the DLL with the Paint that it´s install in my computer and works, but when i tried to do the same with the project but nothing. Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 10, 2008 Share Posted January 10, 2008 Huh? What you're describing and asking makes absolutely no sense at all. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Andrew D Posted January 10, 2008 Share Posted January 10, 2008 Hi,The other day I found a plugin (Conditional Hue/Saturation plugin) and I tried to add the project of this plugin but I don´t really know how to do it. I tried to use the DLL with the paint project but it didn´t work. Does anybody can help me??? I already tried the DLL with the Paint that it´s install in my computer and works, but when i tried to do the same with the project but nothing. Any plugin .dll's go into the effects folder of the Paint.NET directory folder. Any source code "project" files get opened in Visual Studio 2005/8 or Visual Studio C# Express 2005/8. Link to comment Share on other sites More sharing options...
jmf1982 Posted January 10, 2008 Author Share Posted January 10, 2008 "Any source code "project" files get opened in Visual Studio 2005/8 or Visual Studio C# Express 2005/8." I don`t know if you know about the plugin that i´m talking about but it comes with a dll (this one goes to the effects folder of Paint.NET) and the source code of the effect (i guess i can add this code to the Paint.NET project) anyway, I had no problem with the dll. The problem is with the source code , i´m trying to add it into the Paint.NET project but nothing, i don´t know how to do it. This de web page where i download the plugin: http://www.evanolds.com/pdnhs.html Thanks. Link to comment Share on other sites More sharing options...
Andrew D Posted January 10, 2008 Share Posted January 10, 2008 "Any source code "project" files get opened in Visual Studio 2005/8 or Visual Studio C# Express 2005/8."I don`t know if you know about the plugin that i´m talking about but it comes with a dll (this one goes to the effects folder of Paint.NET) and the source code of the effect (i guess i can add this code to the Paint.NET project) anyway, I had no problem with the dll. The problem is with the source code , i´m trying to add it into the Paint.NET project but nothing, i don´t know how to do it. This de web page where i download the plugin: http://www.evanolds.com/pdnhs.html Thanks. You don't need to. You don't need to add the source code to the PDN Source Code. Just leave the source code stuff alone, it's only the .dll which you need unless your interested in Paint.NET Plugin development. Link to comment Share on other sites More sharing options...
jmf1982 Posted January 10, 2008 Author Share Posted January 10, 2008 I forgot to say that. I´m interested in the development, that`s why i´m trying to add the source code into the Paint.NET project. Is it possible? Thanks. Link to comment Share on other sites More sharing options...
pyrochild Posted January 10, 2008 Share Posted January 10, 2008 Yes, it'll work, but you'll need to either set the build output directory to the same as the pdn project, or use a post-build event that copies it there. ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
jmf1982 Posted January 14, 2008 Author Share Posted January 14, 2008 I don`t want to be annoying but I can't steel run the project with the conditional Hue/Saturation effect. I don't know if there is another way to do that, does anybody try to run the code of this effect from or with the PAint.NEt project? I don't where to add this code into the Paint.NET project. Somebody help me please. Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 14, 2008 Share Posted January 14, 2008 I don't think Evan Olds has provided the source code for his plugin. So, please stop asking for it. There is only extremely limited support provided for the Paint.NET source code in the first place. Thread Closed The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
