Text - help plz
Well,
1. Make sure you have the Text tool selected and you've selected a location on the picture to type.
2. Make sure your primary color isn't the same as the background.
Also, it's a good idea to type text on a new layer so that it's easier to edit later, but that's not necessary.
Let me know if this helps!
Make sure you don't have an active selection ( :EllipseSelectTool: :SelectAll: etc.) when trying to use the text tool.
If you try to type outside of your current selection it won't let you--nothing shows up.
Just press ESC or click :Deselect: before clicking :TextTool:
Click to play:
It may also be because the font your trying to use isn't compatitble with PDN, actually, that gives me an interesting question, why does it only allow certain file types? It's more for curosity than wanting it fixes, though.
Paint.NET uses the GDI+ graphics system which supports TrueType Fonts only.
Click to play:
