Bob Posted December 16, 2005 Share Posted December 16, 2005 What error? Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
nes2989 Posted December 16, 2005 Share Posted December 16, 2005 ok now i'm registered. I can't figure it out. it starts to install then instantly says there was an error Quote Link to comment Share on other sites More sharing options...
Bob Posted December 16, 2005 Author Share Posted December 16, 2005 What's your system configuration (operating system, etc.)? Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
nes2989 Posted December 16, 2005 Share Posted December 16, 2005 i'm runnig XP proffesional with service pack 2. 512 ram, pentium 4 2.8 gHz. about 120g hd, 256 meg video card. Quote Link to comment Share on other sites More sharing options...
nes2989 Posted December 17, 2005 Share Posted December 17, 2005 bumpity bump Quote Link to comment Share on other sites More sharing options...
nes2989 Posted December 18, 2005 Share Posted December 18, 2005 somebody help me out here! I didn't want to triple post but no one will help me out. Quote Link to comment Share on other sites More sharing options...
DenDem Posted December 18, 2005 Share Posted December 18, 2005 I know it's too obvious ,BUT.... May be you need to install .NET ? Quote Link to comment Share on other sites More sharing options...
nes2989 Posted December 18, 2005 Share Posted December 18, 2005 i already have .NET installed, but thanks for the effort Quote Link to comment Share on other sites More sharing options...
Illnab1024 Posted December 18, 2005 Share Posted December 18, 2005 are you sure there is no dialog with an option to debug? Quote ~~ Link to comment Share on other sites More sharing options...
nes2989 Posted December 19, 2005 Share Posted December 19, 2005 absolutely. it acts like it is about to install, then it says there was an error and the only thing i can do is click finish Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 19, 2005 Share Posted December 19, 2005 Do you already have a version of Paint.NET installed? If so, try first uninstalling it manually via Add / Remove Programs. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
nes2989 Posted December 19, 2005 Share Posted December 19, 2005 i check just to make sure and there isn't a version installed on my computer. Quote Link to comment Share on other sites More sharing options...
nes2989 Posted December 19, 2005 Share Posted December 19, 2005 woohoo! problem solved. off of a hunch i uninstalled windows installer 3.1, and before i re-installed it tried paint.net again and it worked! thanks for all of the help, and who would've thunk it? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 19, 2005 Share Posted December 19, 2005 Well I don't know if it's worth uninstall a major Windows component in order to get Paint.NET to work. I'm in the process of putting up v2.6 Alpha 2. This probably won't fix the problem but it will provide an error code number when it gives you the "There was an error" message. This number maps to something like ERROR_INSTALL_REMOTE_DISALLOWED (just an example) which should help me figure out what's going on. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
