Mr Frojo Posted April 5, 2007 Share Posted April 5, 2007 Ive been getting tons of problems with Paint.net lately. First off, im being forced to use a different computer than usual. At first, it wouldnt install. The microsoft install cleanup found in the install/uninstall sticky fixed that though. Now im having problems with plugins. I downloaded some plugins, moved them to Paint.NET\Effects, but they arn't showing up in paint.net. Any idea how to fix this? Quote I'm still alive! Link to comment Share on other sites More sharing options...
BoltBait Posted April 5, 2007 Share Posted April 5, 2007 Right-Click on the dll in explorer and choose "properties". Look at the bottom of the General tab and see if there is an "unblock" button. If there is, click it, then click OK. Quote Download: BoltBait's Plugin Pack | CodeLab | and a Computer Dominos Game Link to comment Share on other sites More sharing options...
Mr Frojo Posted April 5, 2007 Author Share Posted April 5, 2007 I already did that, and im still not seeing them. Quote I'm still alive! Link to comment Share on other sites More sharing options...
Rick Brewster Posted April 5, 2007 Share Posted April 5, 2007 Are you using :pdn: Paint.NET v3.05? (... of course you are, if you're following the rules ) Make sure PdnLib.dll is gone from your installation directory. Sometimes this happens if the installer says you need to restart, but then you don't restart. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Mr Frojo Posted April 5, 2007 Author Share Posted April 5, 2007 Yes, im using 3.05. I dont see PdnLib.dll in the installation directory Quote I'm still alive! Link to comment Share on other sites More sharing options...
Mr Frojo Posted April 6, 2007 Author Share Posted April 6, 2007 Anybody have any idea whats going on to cause this? Ive tried all i think of, but can't fix it Quote I'm still alive! Link to comment Share on other sites More sharing options...
