line/curve tool help
No it is not possible. Once the line is committed to the canvas it is rendered as a collection of pixels on the layer. The Line/Curve tool has no knowledge or memory of the previous lines drawn.
If you placed your lines on their own layer it would be a simple matter to delete the old line and redraw it. Alternatively, a line on it's own layer might be able to be manipulated or distorted usng other tools. If it shares the layer with other image elements you will have to do some complex selection to restrict the distortion to just the line.
This is the power of layers. Get used to using them and you will wonder how you ever did without them :)
You're welcome gaz9012. Good luck with the logo.
