(Light) Edge for my logo
Hello,
I have draws a logo for my homepage the last few days - It was quite hard but now I'am almost satisfied.
Here it is:
post-83802-0-23239800-1387871330_thumb.p
I find it quite OK but I'am not satisfied with the edges.
Is there any possibility to make the crossover from the logo to the background like a light does?
 I would be glad for any suggestion.
Thanks a lot and happy christmas.
Generic1
You should have read the relevant article by david.atwell here:
I think the title of this post should be changed to something like this:
Warning!
Before starting a project in Paint.NET read this:
DPI and YOU - Understanding Resolution for Print and WEB
First page should look like this:
Happy Christmas to all!
xod- thank you for recommending my tutorial, but I'm not sure how it's applicable here. :)
Oh, do you mean the bit about "work large then shrink down to save?" If so, then yes, that is what should be done and will probably help greatly here. :)
Yes, this is about: work large then shrink down because AA's Assistant not solve the problem.
Thanks for this very very useful tutorial.
Do you mean put glare on the logo like this? Or maybe smooth the edges like this? Or something else?
If it's smooth edges here's an example using TR's SplineMaster:
http://forums.getpaint.net/index.php?/topic/27512-trs-splinemaster-v133-a-line-maker-dec27-2013-utc/
Edited by TechnoRobbo
TRsSig.png?raw=1
