TR's Str8Edge Tool V1.1
Smooths out jagged edges on a Cut-Out.
(For those of use who's hands are not that steady)
Version 1.1 Updated for Paint.net 4.0
Menu:
Effects->Object
Str8Edge.PNG?raw=1
Deselect before using.
YouTube Example
Composite of tiger done with Lasso and Str8Edge tool. No Edge Feathering!!!
(Minimal Cleanup - Hand drawn  whiskers)
Hand Selected Tiger
Str8EdgeTiger.png?raw=1
The Code
Hidden Content:
// Compiler options:  /unsafe /optimize /debug- /target:library /out:"C:\Program Files\Paint.NET\Effects\TRsStr8Edge.dll"
using System;
using System.Text;
using System.Windows;
using System.Reflection;
using System.Windows.Forms;
using PaintDotNet;
using PaintDotNet.Effects;
using PaintDotNet.IndirectUI;
using PaintDotNet.PropertySystem;
using System.Collections.Generic;
using System.Drawing;
using System.Drawing.Text;
using System.Runtime.CompilerServices;
using System.Runtime.InteropServices;
[assembly: AssemblyTitle("TRsStr8EdgePlugin")]
[assembly: AssemblyDescription("TRsStr8Edge Plugin for Paint.NET. (Compiled by Code Lab v1.8)")]
[assembly: AssemblyConfiguration("")]
[assembly: AssemblyCompany("TechnoRobbo")]
[assembly: AssemblyProduct("TRsStr8EdgePlugin")]
[assembly: AssemblyCopyright("Copyright © TechnoRobbo")]
[assembly: AssemblyTrademark("")]
[assembly: AssemblyCulture("")]
[assembly: ComVisible(false)]
[assembly: AssemblyVersion("1.1.*")]
namespace TRsStr8EdgeEffect
    public class PluginSupportInfo : IPluginSupportInfo
        public string Author
            get
                return "TechnoRobbo";
        public string Copyright
            get
                return ((AssemblyCopyrightAttribute)base.GetType().Assembly.GetCustomAttributes(typeof(AssemblyCopyrightAttribute), false)[0]).Copyright;
        public string DisplayName
            get
                return ((AssemblyProductAttribute)base.GetType().Assembly.GetCustomAttributes(typeof(AssemblyProductAttribute), false)[0]).Product;
        public Version Version
            get
                return base.GetType().Assembly.GetName().Version;
        public Uri WebsiteUri
            get
                return new Uri("http://www.technorobbo.com");
    [PluginSupportInfo(typeof(PluginSupportInfo), DisplayName = "TRsStr8Edge")]
    public class TRsStr8EdgeEffectPlugin : PropertyBasedEffect
        public static string StaticName
            get
                return "TR's Str8 Edge";
        public static Image StaticIcon
            get
                return null;
        public TRsStr8EdgeEffectPlugin()
            : base(StaticName, StaticIcon, "Object", EffectFlags.Configurable)
        public enum PropertyNames
            Amount1
        protected override PropertyCollection OnCreatePropertyCollection()
            List<Property> props = new List<Property>();
            props.Add(new Int32Property(PropertyNames.Amount1, 1, 1, 20));
            return new PropertyCollection(props);
        protected override ControlInfo OnCreateConfigUI(PropertyCollection props)
            ControlInfo configUI = CreateDefaultConfigUI(props);
            configUI.SetPropertyControlValue(PropertyNames.Amount1, ControlInfoPropertyNames.DisplayName, "Amount");
            return configUI;
        bool noskip = true;
        protected override void OnSetRenderInfo(PropertyBasedEffectConfigToken newToken, RenderArgs dstArgs, RenderArgs srcArgs)
            this.Amount1 = newToken.GetProperty<Int32Property>(PropertyNames.Amount1).Value;
            noskip = true;
            base.OnSetRenderInfo(newToken, dstArgs, srcArgs);
        protected override void OnCustomizeConfigUIWindowProperties(PropertyCollection props)
            // Change the effect's window title
            props[ControlInfoPropertyNames.WindowTitle].Value = "TR's Str8 Edge - V 1.1";
            base.OnCustomizeConfigUIWindowProperties(props);
        protected override unsafe void OnRender(Rectangle[] rois, int startIndex, int length)
            if (length == 0) return;
            for (int i = startIndex; i < startIndex + length; ++i)
                Render(DstArgs.Surface, SrcArgs.Surface, rois);
        #region User Entered Code
        // Submenu: Object
        // Name: TR's Str8 Edge
        // Title: TR's Str8 Edge - V 1.1
        // Author: TechnoRobbo
        // URL: http://www.technorobbo.com
        #region UICode
        int Amount1 = 1; // [1,20] Amount
        #endregion
            if (noskip)
                Rectangle sel = EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt();
                dst.CopySurface(src, sel.Location, sel);
                noskip = false;
                try
                    ColorBgra CP = new ColorBgra();
                    int[] offx = { -1, 0, 1, -1, 1, -1, 0, 1 };
                    int[] offy = { -1, -1, -1, 0, 0, 1, 1, 1 };
                    byte[,] agrid = new byte[sel.Width, sel.Height];
                    byte[,] bgrid = new byte[sel.Width, sel.Height];
                    for (int oy = sel.Top; oy < sel.Bottom; oy++)
                        for (int ox = sel.Left; ox < sel.Right; ox++)
                            CP = src.GetBilinearSampleClamped(ox, oy);
                            bgrid[ox, oy] = (byte)((CP.A == 0) ? 0 : 255);
                    for (int z = 0; z < Amount1; z++)
                        Array.Copy(bgrid, agrid, agrid.Length);
                        for (int y = sel.Top; y < sel.Bottom; y++)
                            for (int x = sel.Left; x < sel.Right; x++)
                                if (agrid[x, y] != 0)
                                    int Threshold = 255;
                                    int Sigma = 0;
                                    for (int i = 0; i < 8; i++)
                                        int nx = Int32Util.Clamp(offx + x, 0, sel.Width - 1);
                                        int ny = Int32Util.Clamp(offy + y, 0, sel.Height - 1);
                                        Threshold = Math.Min(agrid[nx, ny], Threshold);
                                        Sigma += agrid[nx, ny];
                                    if (Threshold == 0)
                                        CP = src.GetBilinearSample(x, y);
                                        if (Sigma >= 1275)
                                            CP.A = 255;
                                        else
                                            CP.A = 0;
                                            bgrid[x, y] = 0;
                                        dst[x, y] = CP;
                                } //if
                            } //x
                        } //y
                catch (Exception e) { }
            else
                ColorBgra CP = dst[0, 0];
                dst[0, 0] = CP;
        #endregion
TRsStr8Edge.zip
Edited by TechnoRobbo
  • Upvote 3
TRsSig.png?raw=1
How it Works
The tool examines each pixel twice. First it looks for the tell-tale pattern of an edge.
Then it looks for the tell-tale pattern of a straight edge.
An edge is found when an adjacent pixel being transparent.
a straight edge is found when the sum of the adjacent pixels alpha is equal or higher than 1275!
If the pixel is not partof a straight edge - it's removed.
Why 1275? a Opaque pixel has a Alpha value of 255. 1275 is 255 times 5.
Str8EdgeHow.PNG?raw=1
The tool allows for 20 consecutive passes.
TRsSig.png?raw=1
  • 2 months later...
  • 4 weeks later...
