Start Up Problem, please help!
I'v been using Paint.Net for a long time and I recently have been having this issue.
I tried unistalling it but I keep getting this error.
I don't know what to do at all and I can't seem to find anything about it. Please help.
System: Windows 7 Premium 32-Bit
I was about to point you to the Paint.NET repair application (find it in your Paint.NET directory), but you've created a separate problem by trying to uninstall.
You'll need to remove the remnants of Paint.NET before re-installing a new version.
Follow this link:  http://forums.getpaint.net/index.php?/topic/692-install-update-or-uninstall-trouble-read-this/  and read the second post carefully.
Once you've cleaned out your system, download a brand new copy of Paint.NET from the Paint.NET website and install normally.
Good luck! :)
Good luck! :)
I tried it but it still didn't work. I still get the same issue.
Did you download a new version or did you try to re-install the previous download?
If you tried the same one, run the Windows Installer CleanUp utility again then try a new download.
