MissClara Posted January 27, 2013 Share Posted January 27, 2013 Hello! I am a newbie at Paint.NET and I am a HUGE fan of PDN, I wanted to try out new stuff. So, can you please help me learn on how to do these graphics below? Please make the explanations as simple as possible. I know how to install plugins, just in case! Thanks a lot. These graphics : Quote Link to comment Share on other sites More sharing options...
barbieq25 Posted January 27, 2013 Share Posted January 27, 2013 What did you want to know, how to make the background or get the text outline? The link that Welshblue just posted will certainly help with the background. Remember to work in layers. Put as much as you can on a new layer & save often! Before you start you will need to find & install the plugin from Bolt Bait called Outline Selection Beta. Once you have the background, add the text on a new layer. Select the Magic Wand, set the flood fill to Global. Click anywhere outside the text. Press CTRL + I to invert the selection. Now use the Outline Selection Beta to outline the text or failing all that you could use Drop Shadow, playing with the settings until you get what you want. Another plugin you might find useful is the Object Edge from Red Ochre. I started writing a bit of a tute but Welshy's link is much better Now I might just go ahead & finish the image Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
pdnnoob Posted January 27, 2013 Share Posted January 27, 2013 This plugin might help you with the circles Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
barbieq25 Posted January 27, 2013 Share Posted January 27, 2013 (edited) Same as the plugin for the circles used in Welshy's post. I have a plugin "Autochrome" in my Artistic effects but cannot find it in the plugin list. Looks very similar to Auto Chrome Noise but works more like the random fill. I will put this in another thread too. I strarted with a black background. You can duplicate the circle layers, enlarge some by using Rotate/Zoom from the Layers menu. Play with the opacity & blend modes of the layers by double clicking the layer got get the properties box or whichever method you prefer. Lots of layers, lots of different blend modes & lots of sizes is what I did then on a layer of its own, I painted the edge (quite a large edge, black, then did a massive blur. or you could merge all of the colour layers & then use a transparent gradient. EDIT: You pipped me to the post! Yes, I read the other's posts & even looked through the tute which I think is really good & might have to do something with it. Thanks Welshy! Edited January 27, 2013 by barbieq25 Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
MissClara Posted February 1, 2013 Author Share Posted February 1, 2013 Well, I wanted to know how to do both. @Barbie- Can I see your final result? o; Thanks for the reply guys! I really appreciate it. J ust another question, how do you do the texts on the graphics I posted above? Quote Link to comment Share on other sites More sharing options...
MissClara Posted February 1, 2013 Author Share Posted February 1, 2013 UPDATE: I came up with this: http://prntscr.com/r62mf What did you guys think about it? :] Thanks a bunch. Any suggestions with the graphic I made? Note: How do you do drop shadow? Quote Link to comment Share on other sites More sharing options...
barbieq25 Posted February 1, 2013 Share Posted February 1, 2013 I think you did a very good job with this image. I will finish mine at some point & upload it Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
MissClara Posted February 2, 2013 Author Share Posted February 2, 2013 Thankyou loads! :] Looking forward to see urs. Quote Link to comment Share on other sites More sharing options...
barbieq25 Posted February 2, 2013 Share Posted February 2, 2013 Ok Miss Clara, here is my interpretation of the graphics. I'm glad you asked this question because I had always wnated to try sonething like this & now I know Click the thumbnail to see it properly as it is a 1920 x 1080 wallpaper. Any of the above tutes & tips will get you close to what you want. Experiment & have fun Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
MissClara Posted February 3, 2013 Author Share Posted February 3, 2013 Wow! Nice My final outcome: http://prntscr.com/re92d Quote Link to comment Share on other sites More sharing options...
barbieq25 Posted February 3, 2013 Share Posted February 3, 2013 Well done! Looks great. Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
