nickp88 Posted December 4, 2011 Share Posted December 4, 2011 Okay, so I'm making a signature to use on a forum I go to. The GIF exporter works okay, but It is low quality and I like the way the animinated PNGs look better. HOWEVER, everytime I export it in PNG format, the speed of the gif is WAY too slow, and everytime I mess with the settings It just won't go any faster. I've set the delay on 1, which is the lowest it can go, and it is still too slow. Example: My Signature Exported In Animated GIF format My Signature Exported In Animated PNG format PLEASE help! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted December 4, 2011 Share Posted December 4, 2011 A forum that allows such large signatures? Remind me to never go there. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
minners71 Posted December 4, 2011 Share Posted December 4, 2011 ^Exactly what I thought Quote Link to comment Share on other sites More sharing options...
nickp88 Posted December 4, 2011 Author Share Posted December 4, 2011 A forum that allows such large signatures? Remind me to never go there. I resize them using a bb code Quote Link to comment Share on other sites More sharing options...
jim100361 Posted December 4, 2011 Share Posted December 4, 2011 (edited) I resize them using a bb code I believe the size itself may be the issue (I believe the following is true): a.) Having a smaller size means less load and display time because there is less data. b.) The smaller size should also mean the display should be sharper. c.) Resizing in BBCode has no real effect on a & b above because it's contents doesn't really change - all the data (file size(s)) which comprise(s) the images are still intact meaning longer load and display time. As a test, try reducing all the images and then compile into the animation and see if it improves. You may also wish to take a look at this thread: http://forums.getpaint.net/index.php?/topic/21842-how-to-install-animated-image/ Edited December 4, 2011 by jim100361 Quote Link to comment Share on other sites More sharing options...
nickp88 Posted December 4, 2011 Author Share Posted December 4, 2011 I believe the size itself may be the issue (I believe the following is true): a.) Having a smaller size means less load and display time because there is less data. b.) The smaller size should also mean the display should be sharper. c.) Resizing in BBCode has no real effect on a & b above because it's contents doesn't really change - all the data (file size(s)) which comprise(s) the images are still intact meaning longer load and display time. As a test, try reducing all the images and then compile into the animation and see if it improves. You may also wish to take a look at this thread: http://forums.getpai...animated-image/ Tried, didn't work Quote Link to comment Share on other sites More sharing options...
