100percentscottish Posted November 2, 2011 Share Posted November 2, 2011 hi all am trying to make a background for my blog tv site on net paint but when i try do the castle name logos on both side of the page it will not work any help be great you can have a look here http://www.blogtv.com/People/feb82000 any net paints tips for me to make it work on both sides of the page Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 2, 2011 Share Posted November 2, 2011 The problem you're having is a combination of the image width and the HTML you're using to display it. The image is 600 pixels wide and you're asking for the image to be repeatedly tiled across the background. body{background-image:url('http://Storage.blogtv.com/Albums/3/143008/site/112201147259.jpg');background-repeat: repeat;} Now you're never going to know what screen size the viewer is using, so tiling the image to exactly line the logos up on the sides is a really hit-and-miss affair. What you would be better doing is using the background property to display the left logo, then define a new right aligned <div> to display the right logo. In doing so you can use the same image, but make it a thin strip with the word "live" centered under the word 'castle' so it looks the same on both sides of the screen. If you have problems with the image, continue asking questions in this thread. If you're having problems with the HTML then the thread to post in is this one: http://forums.getpai...ign-discussion/ <Because this is not a tutorial, 'Creations' is not the place for it. moved to Paint.Net Discussion & Questions> Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
