grandmastersteve Posted December 3, 2010 Share Posted December 3, 2010 Hi. I'm a noob and this is my first post to a simple idea I imagine, I just simply cannot do it! My brother has helped me do a design from a wallpaper using a t-shirt template, he used layering, magic wand and then just tweaked some effects. He explained how to do it (ages ago), however I cannot remember and figure out where I'm going wrong or If I need more plugins ect. I'm using the standard 3.5.6 version, no extra anything. Here's the Wallpaper and the T-Shirt design. If someone would be so kind to explain how to do it, It would be much appreciated. Here's a T-Shirt Template to start with. Thank You in advance and Sorry if this is a dumb topic or if there are any other inaccuracies with it Quote Link to comment Share on other sites More sharing options...
becauseilearn Posted December 3, 2010 Share Posted December 3, 2010 I don't see doing this with realism without using a plugin, such as Alpha-Displacement. Quote Link to comment Share on other sites More sharing options...
grandmastersteve Posted December 3, 2010 Author Share Posted December 3, 2010 Thats a nice plugin, will try and implement it. My brother may have used something similar but not too sure. That's useful for keeping the creases and realism of the T-Shirt any idea how to get the Wallpaper image onto a T-shirt Template like the one shown. The use of layering is probably the answer.. I just cannot figure that part out Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 3, 2010 Share Posted December 3, 2010 Resize the Wallpaper image so that it will cover the T-shirt adequately. Put it on a layer above the T-shirt with its Blending mode set to Darken. You'll need to use one of the various cutting-out methods to trim off the Wallpaper image where it extends beyond the edge of the T-shirt. Quote Link to comment Share on other sites More sharing options...
liamvanvel Posted December 3, 2010 Share Posted December 3, 2010 this was my attempt Quote Link to comment Share on other sites More sharing options...
grandmastersteve Posted December 3, 2010 Author Share Posted December 3, 2010 Put it on a layer above the T-shirt with its Blending mode set to Darken. Awesome, that's what I was missing, I can now play around with it get some more designs made. Thank You for this and also cheers becauseilearn good plugin there I can mess about with. Quote Link to comment Share on other sites More sharing options...
mountnman Posted December 3, 2010 Share Posted December 3, 2010 (edited) remember- if you put that white tshirt on a black background(just makes it easier i think) and use the magic wand to select it- then switch to the layer with the wallpapaer, not only will you be able you precisely cut out you shape but you can use the move seletion tool (white arrow- on your tool box) to move the area to be cut out to EXactly what you want- then Ctrl-I to invert selection and delete Edited December 3, 2010 by mountnman Quote SARCASM- Just one of the many services I offer free to the public. Link to comment Share on other sites More sharing options...
