Peter Philipp Posted May 28, 2010 Share Posted May 28, 2010 I have a Plustek OpticPro ST24 scanner which worked fine under XP. I set it to XP mode to be able to use it under Win 7 64 Bit. It works (not as TWAIN) with different programs, but NOT with Pait.Net. There, "scanner" is marked in grey and won't work. Does anybody have an idea how I can fix this? Quote Link to comment Share on other sites More sharing options...
Dae Posted May 28, 2010 Share Posted May 28, 2010 scanne avec ton programme de scannage habituel enregistre dans tes document puis ouvre avec PaintDotNet The post roughly translates (via Babel Fish http://babelfish.yahoo.com/) as: scanne with your usual program of scannage records in your document then opens with PaintDotNet Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 29, 2010 Share Posted May 29, 2010 @Dae: Thank you for trying to help with this inquiry. Our forum Rules specify that posts must be in English (except the Localization section - see rule #22). I understand that English is not your first language, but we must insist that English be used. @Peter Philipp: just confirming that your scanner worked in PDN under XP, but not with Win7? The only scanner support I can draw your attendtion to is the TWAINable plugin. If this is no help then perhaps Dae's advice is a reasonable workaround. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
