brackfrack Posted February 15, 2010 Share Posted February 15, 2010 I'm not sure if another user has asked this already, but if they did, point me to the right link. Recently I purchased a new computer that runs Windows 7.(I used to have windows XP). When I first received the computer the computer(Thursday February 11), the first thing i did was Install Paint.net. It is now that I'm trying to install new effects and I get the following message when extracting the files the the "effects" folder: I'm not sure what I am supposed to do. Please help as soon as possible. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 15, 2010 Share Posted February 15, 2010 Moved to Troubleshooting Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 15, 2010 Share Posted February 15, 2010 I'm not sure what you're supposed to do either because I can't see the error messages behind the blurring. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
brackfrack Posted February 15, 2010 Author Share Posted February 15, 2010 The most important one says: " ! C;\User\(name)\AppData\Local\Temp\CurtisBlack.Common.3.5.beta.1.zip: Cannot create CurtisBlack.Common.dll" And Below that it says "! Access is denied" Does that help? (obvioulsly I was downloading Curtis' Plug-in Pack) Quote Link to comment Share on other sites More sharing options...
pyrochild Posted February 15, 2010 Share Posted February 15, 2010 You need administrative privileges to install new plugins. If you're not your computer's administrator, you should ask him/her to do it for you. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
brackfrack Posted February 15, 2010 Author Share Posted February 15, 2010 I own my computer....... Quote Link to comment Share on other sites More sharing options...
Sarkut Posted February 15, 2010 Share Posted February 15, 2010 Try downloading the zip to the Desktop, left-click to open (no WinRAR), then copy/paste the DLLs to the Effects folder. Best to do this with the Paint.NET program closed. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 15, 2010 Share Posted February 15, 2010 I own my computer....... I'm guessing you were using XP until recently? Vista and Win7 have a new security system and you don't have access to write to locations like C:\Program Files\* unless you "elevate" (or confirm or give permission, depending on context). This helps a LOT to make sure malicious programs can't go doing bad things (e.g. replacing system files) without your knowledge. Running everying as Administrator all the time got XP into a lot of trouble. The version of WinRAR you're using probably isn't written with this in mind; maybe you have an old version. Sarkut's work around should work too. http://en.wikipedia.org/wiki/User_Account_Control Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
brackfrack Posted February 15, 2010 Author Share Posted February 15, 2010 Try downloading the zip to the Desktop, left-click to open (no WinRAR),then copy/paste the DLLs to the Effects folder. Best to do this with the Paint.NET program closed. This worked. Thanks Sarkut Quote Link to comment Share on other sites More sharing options...
